Hardware Advice
Hello everybody,
I am in the process of upgrading my workstation hardware, but I've come to hear yor expert advice whether it's better to spend more money on CPU or GPU. I know for years VRED has been CPU only, but the latest versions I hear allow you to render proper still shots (not viewport) with the GPU instead of hammering the CPU.
I am definitely going for AMD Threadripper, but there is a significant cost difference between the 32 core 3970X and the 64 core 3990X. I suppose the following question can be asked knowing if two GPUs (for example RTX3080 or RTX3090) will outperform a single CPU like these two in a still shot rendering - lets say 4k resolution. If rendering on the GPUs is now reliable in VRED and much faster compared to rendering on CPU I suppose it makes no sense to spend so much money for top of the line CPU. Has anyone made any tests of this kind to compare and share the results?
Another question related to the VR performance. Would you suggest installing a second graphic card makes a huge performance jump in VR? For example I am wondering if I will have a better performance having two RTX3080 10GB vs one RTX3090 24GB.
If the CPU vs GPU question above is in big favour for the GPUs...and two GPUs also make a lot more sense in VR then I suppose I can just hook two of the latest graphic cards and extend the life of the current machine.
Many thanks in advance!
Best Regards,
M
