Hello, everyone!!
I have a VRED Binary file (.vpb) with a particular 3d model being used. I had imported a .wire file for use on this VRED binary file. Sadly, I lost the .wire file I had used. Is there anyway to export a .wire file from the VRED .vpb file??
On Autodesk Knowledge Network help, I saw a post saying that you can export a .wire file using the Maya scene option. I see the Maya Scene option on my software but I don't see the .wire option. On help, it says the following:
Export
The export function allows the export of the scene geometry, images, sequencer batches, and variants.
Scene: Allows exportation of the scene in different data types. The default setting is *.vpb. Other supported types are as follows:
Maya® Scene: .ma .mb .wire
Please help me on how I can export a .wire file.
Thank you in advance.
