Dynamic Animation FPS change or duration change
extern.Sanju.Mathew
Message 1 of 1
extern.Sanju.Mathew
May I know if any of you have been successful in dynamically changing the FPS or increasing or decreasing duration of the animation when the animation is playing using python script? I am looking for the python code to change FPS or duration. I have to change the animation play speed dynamically while the same animation is playing. It would be great if any of you can support with some ideas.
Sanju
Replies (0)
