Hi there!
In the examples there is a vrVideoGrab example that changes the video stream size by passing the resolution to the constructor of vrVideoGrab
screen = createPlane(2000, 1000, 1, 1, 0,0,0) screen.setRotation(90,0,0) screen.setTranslation(0, 0, 500) # vg = vrVideoGrab(screen, "LifeView") # specify a resolution. vg = vrVideoGrab(screen, "Integrated Webcam", 768, 576) vg.setActive(true)
However, any video stream resolution I put in the constructor fails to actually change the video stream. The result is always something like this (for any VRED version 2017, 2018 and 2019):
Setting video resolution to 768 x 576 vrFrameGrabber::init : Couldn't set format, trying default resolution 1280 x 720 vrFrameGrabber::init : Couldn't set format.
Is there any way to change the video resolution in vrVideoGrab?
I want to do some processing on the video frames and therefore have to access the pixel data. But accessing 1920x1080 pixels in real time slows down performance a bit... Lowering the resolution would be no problem, however.
Alternatively:
Do you think it would be possible to grab the video stream with openCV and inject the frame data into a material?
