API 2 check node type in external Python module
j.kaestle
j.kaestle
I am writing an external Python module in which I want to check the type of the selected node.
'if node.isType(vrdTransformNode)' works fine in the VRED Script Editor.  When using the external module, I get the error that "vrdTransformNode" is not defined. What must I add to the script, to make object types known.
Thanks a lot
Jochen
Christian_Garimberti
Hi, try to use node.isType(vrKernelServices.vrdTransformNode)
or maybe just importing vrKernelServices before, but i never tried
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
j.kaestle
thank you fro the hint. 'node.isType(vrKernelServices.vrdTransformNode)' also doesn't work. I still get  the error message "NameError: name 'vrKernelServices' is not defined. Did you mean: 'vrMaterialService'?"
Regarding this discussion, it is not recommended to import the services:
Solved: Python Plugin: import vrKernelServices.vrUVService - Autodesk Community - VRED
My workaround now is to use
if (str(type(node)) == '<class \'vrKernelServices.vrdTransformNode\'>')
Best
Jochen
Hi, i made some easy test and it worked for me... in both the Script Editor and as a Script Plugin, without importing the vrKernelService.
i'm working in VRED PRo 2024.2.1. Which version are you using? Maybe older version it doesn't works.
I tried with this in the script editor
def testvrKernelServices2():
    node = vrScenegraphService.getSelectedNode()
    print(node.isType(vrKernelServices.vrdTransformNode))
And this in a script plugin
from PySide6 import QtCore, QtGui, QtWidgets
class testDialog(QtWidgets.QDialog):
    def __init__(self, parent=None):
        super(testDialog, self).__init__(parent)
        self.setWindowTitle('Test')
        boxlayout = QtWidgets.QGridLayout(self)
        self.setLayout(boxlayout)
        self.TestButton = QtWidgets.QPushButton("Test")
        self.TestButton.clicked.connect(self.testvrKernelServices)
        boxlayout.addWidget(self.TestButton, 0, 1)
    def testvrKernelServices(self):
myTestDialog = testDialog(VREDPluginWidget)
myTestDialog.show()
 Best
Chris
j.kaestle
I work with VRED 2024.2
The whole thing is strange. If I start VRED and test it in an empty scene it is working.
If I load my scene, which loads the external modules, it fails:
I will analyze my modules and try to find the cause. If I find it, I will tell you.
Best
Jochen
Hi, maybe you found a bug...
If you put this code in the script editor of new scene just after the Vred Startup, it works.
If you load something new, or create a news cene, it does not work anymore.
Working with script plugins works everytime.
Maybe someone from Autodesk could give a check.
@__daniel.lincoln__
best
Chris
Eduardt_AlbergEZ998
i also tested it and it is weird that its working after vred startup. You have to import the vrKernelServices or you just import the classes you need from the vrKernelServices, just like this:
from vrKernelServices import vrdTransformNode
    print(node.isType(vrdTransformNode))
But be careful. Most classes can be imported normally, classes with a service at the end, such as vrNodeService or vrMaterialService should not be imported in this way, as these are already instantiated in VRED and you replace this instance with the class if you import them in this way.
