Hi Guys, i see the 2023.3.1 Hotfix is ready to be downloaded. I see that the ATF (Autodesk Translation Framework) is updated.
Is it possible to know which upgrades or corrections are in that release?
For example are there updates for Inventor Import?
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Solved by seiferp. Go to Solution.
Hi Chris,
the ATF update is mainly about the SketchUp format and smaller fixes for VRED Design related to the new Scenegraph changes with 2023.3.
Hi Christian , hi Patrick, I heard from good autodesk source that a bug in the tesselation feature has been fixed. Quite important for my work.
Can you confirm Pascal?
The Hotfix doesn´t contain any tessellation issue fixes. Bute VRED 2023.3 does!
