Xline in offset
Xline in offset
Message 1 of 8
Xline in offset
Hi everyone,
I have this lisp: by entering a distance and picking a line it creates Xline in the specified distance and parallel to the selected line.
and I want it to work also if I pick a line in a block, can someone help with that?
(defun c:demo ( / offsetlobject otype ent odist ppt parm pts)
(command "_UCS" "_World" "")
(if
(and
(setq odist (getdist "\nEnter offset distance"))
(setq offsetlobject
(entsel
"\nSelect object to offset"))
(member (setq otype (cdr (assoc 0
(setq ent (entget (Car offsetlobject))))))
'("LWPOLYLINE" "LINE"))
(progn
(setq ppt (vlax-curve-getclosestpointto
(Setq e (car offsetlobject))
(cadr offsetlobject))
parm (vlax-curve-getParamAtPoint e ppt))
(setq pts
(if (eq otype "LINE")
(mapcar '(lambda (dxf)
(cdr (assoc dxf ent)))
'(10 11))
(mapcar '(lambda (v)
(vlax-curve-getPointAtParam e v))
(list (fix parm) (1+ (fix parm))))
(command "_Xline" "_non" (Car pts) "_non" (cadr pts) "")
(command "_.offset" "_Erase" "_Yes" odist ppt pause "")
(command "_UCS" "_V")
Thanks.
Replies (7)
Message 2 of 8
_gile
Did you try just replacing (entsel with (nentsel (line #7)?
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
john.uhden
That's a start, but he'll probably need some coordinate transformations as well.  My XOFFSET function grew a lot bigger than I had originally anticipated, but I also included options for a whole polyline or just a segment and of course choices for layer, color, elevation, etc.
John F. Uhden
Message 4 of 8
Thanks, but it doesn't work.
When I click on a line in a block, it says: Cannot offset that object.
Message 5 of 8
john.uhden
That's because your program actually has to recreate the object in the current drawing and then it can be offset.
John F. Uhden
Message 6 of 8
Kent1Cooper
@Anonymous wrote:
... I want it to work also if I pick a line in a block, can someone help with that? ....
How 'bout this?  I took parts from my Bisector.lsp routine that allows various straight kinds of things and limits it to those, and a little from elsewhere, and hobbled together OffsetToXline.lsp with its OX command [attached].
Compared to the "demo" command posted, even if enhanced to work with nested Lines, OX has these advantages:
It doesn't do it from just Lines, Polylines and [as requested above] Lines that are nested in Blocks, but also from scads of other straight things, such as Rays, other Xlines, parts of Hatch patterns, straight-line parts [only] of Leaders and Dimensions and 3D Solids and Regions, edges of Viewports, Tolerance Boxes, 2D Solids, 3D Faces, Traces and Wipeouts, and  any of those nested in Blocks.  [I wanted to include the linear parts of Tables, but they yield incorrect results because of where MID and END Osnaps "land" on them.]
It doesn't give up on you if you pick on some inappropriate object, but asks again.
It forbids selection of a Polyline or Region or 3D Solid on an arc segment.
It allows the Through option of regular Offset, and displays the current setting [whether Through or a specified distance] and allows Enter/space to accept that as default.
It highlights  the initial Xline while in the Offset command, as a visual clue, since neither the OX nor the demo command "drags" the Offsetting operation from within a (command) function, as regular Offset does.
Kent Cooper, AIA
Message 7 of 8
Thank you very much @Kent1Cooper , that is exactly what I wanted.
Good day.
Eyal
Message 8 of 8
artmitchell51
I know this is old but THANK YOU! I've been looking for something like this!
