Message 1 of 9
After adding 3 deltas and their respective clouds to the drawing set ... it was discovered that all the delta blocks were placed on the cloud layer "a-delta-A" instead of "a-delta"... the intention is for the delta block to remain on while the clouds can be turned off
to solve this problem I need to create a script that selects the "DELTA" block and change it to the "A-DELTA" layer
I've only learned to use and modify one script which allows me to freeze and thaw revision clouds...
any input would help
thank you
