Write to registry
Write to registry
DGRL
Advisor Advisor
Message 1 of 9
Write to registry
DGRL
Dear coders
After searching on Google and forums like this one, there is no other choose for me to post my question here.
Is it possible to write to the windows registry and write the following key types
1. REG_EXPAND_SZ
2. REG_MULTI_SZ
3. REG_QWORD
4. REG_BINARY
I know how to write REG_SZ and REG_DWORD
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Replies (8)
Message 2 of 9
roland.r71
You'll need Acet (AutoCAD Express Tools), afaik, for reading/writing registry keys.
(acet-reg-del <key> [<name>])Delete key or value from Registry.ACET
(acet-reg-get <key> [<name>])Return value from Registry.ACET
(acet-reg-prodkey)Return current product key.ACET
(acet-reg-put <key> [<name> <value>])Write a Registry key or value.ACET
(acet-reg-setactivex alst) ACET2
(acet-reg-tree-get keypath key) ACET
(acet-reg-tree-set keypath lst) ACET
For your request that would be:
(acet-reg-put key [name value])
Arguments
key: Key name to use.
name: If given, value name to write.
value: If given, value to assign to name.
Return Values
T on success.
However: It doesn't say anything anywhere about different key types.
Edit:
Did a quick search, & There's some vl functions doing the same
vl-registry-write (val-name val-data)
But it too doesn't mention types. (are you sure it even matters?)
Message 3 of 9
DGRL
hi @roland.r71
Thanks for the reply
This seems to be a partly solution as you NEED express tools to be installed for this
I am hoping to find a way to do this without the use of 'extra installed' express tools
vl-registry-write is not able to do this afaik
Kind Regards
Message 4 of 9
DGRL
@roland.r71
Well it matters only if you need to write specific data to the reg that requires to use that kind of key
(vl-registry-write)  can only write REG-SZ and REG_DWORD.
Kind Regards
Message 5 of 9
_gile
Hi
As far I know this is not possible simply because AutoLISP does not know types like 64 bits integers, binary data or unexpanded references to environment variables.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 9
DGRL
@_gile
Thanks for the reply and thanks for this info
Will look for other ways to achieve this.
Kind Regards
Message 7 of 9
roland.r71
Just a thought:
If there is a way to execute a .reg file from acad, you could just write your own using lisp & execute.
So, instead of writing straight to the registry, you write a text file (myRegKeys.reg) & import that into the registry. I know the first part is relatively easy, but i'm not sure if you can import the .reg file into the registry from acad/lisp. (otherwise: a double click inwindows file explorer is enough to import the data)
Message 8 of 9
DGRL
@roland.r71
The execution of the .reg needs to be done without user approval and i do not know if that is possible
Have to test this
Thanks for the idea.
Kind Regards
Message 9 of 9
dgorsman
If users have restricted rights that will apply to calls to (vl-registry-write...) as well.
If they do have appropriate rights, this sounds like the perfect job for a dotNET DLL.  Define a couple of extra LISP functions with extra arguments for the other data types.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
