Write / Read some information to block
I write one prorgam, that works good, but i have one problem.
I have some block. I insert one copy of my block to document.
I write to block some code by this function:
(setq spec '((0 . 1) 2 3 4 5 (6 . 7)))
(vlax-ldata-put vla "spec" spec).
So I can read this information by this function:
(vlax-ldata-get vla "spec")
My problem is that this information is in one copy of my block. I want to this information would be in all copies of this block.
If I insert more copies of my block, it would have not this information.
So how I can put this information to block, to read it from any copyes of this block?
Sorry for my English:-(
I got answer on other forum:
We can write information to block definition
; Syntax (BlockLdataPut "MyBlockName" '(1 2 3))
(defun BlockLdataPut (strBlockName lstLdata / entBlockDefinition objBlockDefinition)
(and
(setq entBlockDefinition (tblobjname "block" strBlockName))
(setq objBlockDefinition (vlax-ename->vla-object entBlockDefinition))
(vlax-ldata-put objBlockDefinition "blockldata" lstLdata)
; Syntax (BlockLdata "MyBlockName")
(defun BlockLdata (strBlockName / entBlockDefinition objBlockDefinition)
(if
(and
(vlax-ldata-get objBlockDefinition "blockldata")
(vl-load-com)
