Write attribute and replace block
Message 1 of 20
Hello people
The .lsp attached replaces a polyline with a specific block,
This works perfectly well.
There is the possibility of in addition to replacing them write the attributes based on the closest text.
(defun c:BK_Replace ( / *error* _StartUndo _EndUndo doc spc ss ll ur )
  (vl-load-com)
  ;; Lee Mac 2010 - www.lee-mac.com
  (defun *error* ( msg )
    (if doc (_EndUndo doc))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
	(princ (strcat "\n** Error: " msg " **")))
    (princ)
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
 (defun _EndUndo ( doc )
   (if (= 8 (logand 8 (getvar 'UNDOCTL)))
     (vla-EndUndoMark doc)
 (LM:ActiveSpace 'doc 'spc)
  (if
    (and
      ; Old Code by LeeMac
      ; (setq *dwg (getfiled "Select Block" (vl-filename-directory (cond ( *dwg ) ( "" ))) "dwg" 16))
      ; EDIT by 3dwannab 15-03-18
      (cond
	 (and
	   (setq *dwg (car (entsel "\nSelect Block:")))
	   (eq (cdr (assoc 0 (entget *dwg))) "INSERT")
	   (setq *dwg (vla-get-effectivename (vlax-ename->vla-object *dwg)))
      ; End EDIT
      (ssget "_:L" (list (cons 0 "LWPOLYLINE") (cons 410 (getvar 'CTAB))))
    (progn
      (_StartUndo doc)
      (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
	(vla-getBoundingBox obj 'll 'ur)
	 (lambda ( block )
	   (mapcar
	     (function
	       (lambda ( p )
		 (vlax-put-property block p (vlax-get-property obj p))
	     '(Layer Linetype Lineweight)
	    (lambda ( hyp )
	      (vlax-for h (vla-get-HyperLinks obj)
		(vla-Add hyp (vla-get-Url h) (vla-get-UrlDescription h) (vla-get-UrlNamedLocation h))
	     (vla-get-HyperLinks block)
	  (vla-InsertBlock spc
	    (vlax-3D-point
	      (apply 'mapcar
		     (cons '(lambda ( a b ) (/ (+ a b) 2.))
			   (mapcar 'vlax-safearray->list (list ll ur))
	    *dwg 1. 1. 1. 0.
	(vla-delete obj)
      (vla-delete ss) (_EndUndo doc)
  (princ)
;;--------------------=={ ActiveSpace }==---------------------;;
;;  Retrieves pointers to the Active Document and Space       ;;
;;  Author: Lee Mac, Copyright © 2010 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  *doc - quoted symbol (other than *doc)                    ;;
;;  *spc - quoted symbol (other than *spc)                    ;;
(defun LM:ActiveSpace ( *doc *spc )
  ;; © Lee Mac 2010
  (set *spc (vlax-get-property (set *doc  (vla-get-ActiveDocument (vlax-get-acad-object)))
	      (if (= 1 (getvar 'CVPORT)) 'PaperSpace 'ModelSpace)
(princ (strcat "\nLoaded 'BK_Replace' "))
(princ)
Example dwg
Replies (19)
Message 2 of 20
pbejse
Yes, it is possible.
Message 3 of 20
how to do this?
Message 4 of 20
pbejse
@Anonymous wrote:
how to do this?
From the block do this...
Until you hit at least two TEXT object.
Well, not exactly like that but a box getting bigger each "missed" pass.
That would be nice to code eh? Smiley Happy
Message 5 of 20
ВeekeeCZ
Oh boy, where is Nokia gone now..
Message 6 of 20
pbejse
No One Knows It Actually  Smiley Wink
Message 7 of 20
Moshe-A
@Anonymous  hi,
check this one,  on select objects pick the polyline plus the two texts.
enjoy
moshe
(vl-load-com) ; load activex support
(defun c:bkrpl (/ get_center_point format_text ; local functions
		  BNAME ss0 ss1 ss2 elist p0 p1 attval0 attval1 savAttReq savAttDia)
 (defun get_center_point (ent / AcDbPline MinPoint MaxPoint)
  (setq AcDbPline (vlax-ename->vla-object (ssname ss1 0)))
  (vla-getboundingbox AcDbPline 'MinPoint 'MaxPoint)
  (vlax-release-object AcDbPline)
  (mapcar
    '(lambda (x0 x1)
      (/ (+ x0 x1) 2)
   (vlax-safearray->list MinPoint)
   (vlax-safearray->list MaxPoint)
 ); get_center_point
 (defun format_text (str / p)
  (if (setq p (vl-string-search "/" str))
   (strcat (substr str (1+ p)) "/" (substr str 1 p))
   str
 ); format_text
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (setq BNAME "Example Block") ; const
 (cond
  ((and
    (null (tblsearch "block" BNAME))
    (not (findfile (strcat BNAME ".dwg")))
   (vlr-beep-reaction)
   (prompt (strcat "\nBlock " BNAME " is not exist."))
  ); case
  ( t
   (if (setq ss0 (ssget '((0 . "lwpolyline,text"))))
    (progn
     (setq ss1 (ssadd) ss2 (ssadd))
     (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss0)))
      (setq elist (entget ename))
      (cond
       ((eq (cdr (assoc '0 elist)) "LWPOLYLINE")
        (ssadd ename ss1)
       ((eq (cdr (assoc '0 elist)) "TEXT")
        (ssadd ename ss2)
      ); cond
     ); foreach
     (cond
      ((= (sslength ss1) 0)
       (vlr-beep-reaction)
       (prompt "\nNo polyline selected.")
      ); case
      ((> (sslength ss1) 1)
       (vlr-beep-reaction)
       (prompt "\nto many polylines selected.")
      ); case
      ((= (sslength ss2) 0)
       (vlr-beep-reaction)
       (prompt "\nNo text selected.")
      ); case
      ((= (sslength ss2) 1)
       (vlr-beep-reaction)
       (prompt "\nonly 1 text selected.")
      ); case
      ((> (sslength ss2) 2)
       (vlr-beep-reaction)
       (prompt "\nto many texts selected.")
      ); case
      ( t
       (setq p0 (get_center_point (ssname ss1 0)))
       (setq attval0 (cdr (assoc '1 (entget (ssname ss2 0)))))
       (setq attval1 (cdr (assoc '1 (entget (ssname ss2 1)))))
       (setq savAttReq (getvar "attreq"))
       (setq savAttDia (getvar "attdia"))
       (setvar "attreq" 1)
       (setvar "attdia" 0)
       (command "._insert" BNAME (trans p0 0 1) 1 1 0)
       (if (vl-string-search "/" attval0)
        (command (format_text attval0) attval1)
        (command attval1 (format_text attval0))
       ); if
       (setvar "attdia" savAttReq)
       (setvar "attreq" savAttDia)
       (setq p1 (get_center_point (entlast)))
       (command "._move" "_si" "_last" (trans p1 0 1) (trans p0 0 1))
       (command "._erase" ss1 ss2 "") ; remove origin objects
      ); case
     ); cond
    ); progn
   ); if
  ); case
 ); cond
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
); c:bkrpl
Message 8 of 20
pbejse
@Anonymous wrote:
how to do this?
If your request is for the attached example or drawing of similar condition then its easy.
Message 9 of 20
ВeekeeCZ
Yeah, I guess it's sad, but kinda true.
But you know what... Nice work with words, pBe! I never knew it was an acronym... ever thought of doing that for a living? 😉
Message 10 of 20
ВeekeeCZ
@Anonymous, OK, let's do not spoil it all... and get back to the topic.
Hey Junior, it's not that difficult that you couldn't make in on your own! At least show some trials, that count! I remember some of your programming attempts not that long ago... Where is your enthusiasm gone? Does it have anything to do with that shiny blue badge on the profile of yours?
Message 11 of 20
pbejse
Try
(defun _ImGroot	(bl lw / textfound)
  (if (and
	(setq atbv (vlax-invoke bl 'Getattributes))
	(setq ss
	       (ssget "_X"
		      (list '(0 . "TEXT")
			    '(-4 . ">=,>=,*")
			    (Cons 10 lw)
			    '(-4 . "<=,<=,*")
			    (Cons 10 (mapcar '+ lw (list 3.75 2.75 0.0)))
	(= (setq i (sslength ss)) 2)
    (progn
      (setq textfound
	     ((lambda (lst)
		(mapcar
		  '(lambda (en)
		     (setq str (cdr (assoc 1 (entget en))))
		     (entdel en)
		     (if (setq p (vl-string-position 47 str))
		       (strcat (substr str (+ 2 p)) "/" (substr str 1 p))
		       str
		  lst
	       (vl-remove-if
		 'listp
		 (mapcar 'cadr (ssnamex ss))
      (while (not (vl-string-position 47 (Car textfound)))
	(setq textfound (reverse textfound))
      (mapcar 'vla-put-textstring atbv textfound)
insert it here..
     ... (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
	 (lambda ( block )
	   (_ImGroot block (vlax-safearray->list ll))
	   (mapcar
	     (function
	       (lambda ( p )
Go ahead and play around with it. it missed some of the TEXT objects not on the same positions as the others. Well you get the general idea
Message 12 of 20
pbejse
Smiley Very Happy  Good times BeeKeeCZ.
I missed this, Wish I have more time to engage in this forum.  Fun fun fun..
Message 13 of 20
ВeekeeCZ
Yeah... just a few folks play this card sometimes... glad to see you around!
Message 14 of 20
Many thanks @Moshe-A  you are fantastic !!! I will try to make a multiple selection.
Thank you too @pbejse  @ВeekeeCZ
Message 15 of 20
@pbejse
This is very complex for me, some doubts
works relatively well if it is a small amount of selected objects, when more than 10000 takes many hours to run, is there a possibility of reducing that time?
  (vl-load-com)
    (princ)
  (if
    (and
      (cond
	 (and
      ; End EDIT
    (progn
      (_StartUndo doc)
	 (lambda ( block )
	   (mapcar
	     (function
	       (lambda ( p )
	    (lambda ( hyp )
	    (vlax-3D-point
	      (apply 'mapcar
	    *dwg 1. 1. 1. 0.
	(vla-delete obj)
  (princ)
;;  Arguments:                                                ;;
  ;; © Lee Mac 2010
(princ)
pbejse
  (if (and
	(setq ss
	       (ssget "_X"
		      (list '(0 . "TEXT")
			    '(-4 . ">=,>=,*")
			    (Cons 10 lw)
			    '(-4 . "<=,<=,*")
    (progn
      (setq textfound
	     ((lambda (lst)
		(mapcar
		  '(lambda (en)
		     (entdel en)
		       str
		  lst
	       (vl-remove-if
		 'listp
Message 16 of 20
devitg
One way someone  could help you, if you would help someone  with a true whole .dwg
And a whole specifications about what you want.
Message 17 of 20
pbejse
@Anonymous wrote:
@pbejse
A measly 10,000+?!? ! 😄
I copied the items on the sample drawing and copied the items making it 15,000 and it took  9:34, maybe you meant 100,000?  like most things, 100,000 will take a long time to process. I will have a look later.
Message 18 of 20
@devitg  The file is exactly that, it's just cropped.
@pbejse
I'm being generous in saying 10,000
to be more accurate are 4 parts each with approximately 32,000. No need to bother trying to solve it.
Message 19 of 20
devitg
Please apologize me . Could you explain how ACAD can work on a IMAGE. ??
Message 20 of 20
devitg
Junior , please pardon me . I did no seen your link to download the DWG . I will check it now
