Wipeout routine
Wipeout routine
C.Utzinger
Wipeout routine
C.Utzinger
Hi
I have a Little Problem with the following code:
(defun c:<WipeoutNeu (/ *error* lay cmd ent)
	(defun *error* (errmsg)
    	(if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      	   (princ (strcat "\nError: " errmsg)))
    	(setvar 'CLAYER lay)
	(setvar 'CMDECHO cmd)
	(command-s "_.undo" "_end")
        (command-s "_.u")
	(princ "\nAlles rückgängig gemacht! ")
    	(princ))
	(command "_.undo" "_begin")
	(setq lay (getvar 'CLAYER)
              cmd (getvar 'CMDECHO))
	(setvar 'CMDECHO 0)
  	(command "_.-LAYER" "_m" "-I-Wipeout" "_co" "255" "-I-Wipeout" "")
	(if (setq ent (car (entsel "\nGeschlossene Polylinie wählen oder <Neue zeichnen>: ")))
	    (progn
		(command "_.wipeout" "_p" ent "_y")
		(princ "\nWipeout erstellt! "))
	    (progn
		(command "_pline" (while (> (getvar "cmdactive") 0) (command pause)))
		(command "_.wipeout" "_p" "_last" "_y")
		(princ "\nWipeout erstellt! ")))
	(command "_.undo" "_end")
	(prin1)
) ; end of defun
If you select a unclosed polyline (I know you should select a closed one 😉 ), then the Routine Ends normally with the princ "Wipeout erstellt!".
How can i fix this?
Regards
ВeekeeCZ
Perhaps like this?
    (if (and (= "LWPOLYLINE" (cdr (assoc 0 (entget ent)))) ; selected ent is lwpolyline
             (= 1 (logand 1 (cdr (assoc 70 (entget ent))))) ; it's closed
      (progn
      (princ "\nError: Required closed polyline!"))
    (progn
Just noticed that they've changed the code-window behavior - it's wrapping a text automatically - the code is significantly less readable, imho. 😞
C.Utzinger
Thank you very much!!!
Here my completed code:
        (command-s "_.u")
    	(princ))
	(setvar 'CMDECHO 0)
             (= 1 (logand 1 (cdr (assoc 70 (entget ent))))))
      	(progn
      		(progn
        		(command "_.u")
			(princ "\nFehler: Geschlossene Polylinie erforderlich!")))
        (progn
		(setq ent (entlast))
      			   (progn
			   (princ "\nFehler: Geschlossene Polylinie erforderlich!"))))
	(prin1)
) ; end of defun
