Wipeout routine doesn't work now
HI i am writing simple routine aims to just zoom extend and quit for multble sheets so the script file contains the following
zOOM
e
qsave
quit
and the .bat file is the following
{{{{{{{{{{{{{{{{{{{{{{{{FOR %%V IN (*.DWG) DO START /W "c" "C:\Program Files\Autodesk\AutoCAD 2015\acad.exe" %%V /nologo /b "C:\IssueRoutine.scr"
FOR %%V IN (*.BAK) DO DEL %%V}}}}}}}}}}}}}}}}}}}}}}}}}}}}}
an AutoCAD massage appears as follows
Cannot Find the specified drawing file.
please verify that the file exists
then the after pressing ok the AutoCAD open the browser so can any one please help me solv this problem
thanks for your time
hmsilva
Hi nabsterhema,
i would suggest to hardcode the start path
i.e.
FOR %%V IN (C:\"My"\"Full"\"Path"\*.dwg) DO START /W "c" "C:\Program Files\Autodesk\AutoCAD 2015\acad.exe" %%V /nologo /b "C:\IssueRoutine.scr" FOR %%V IN (C:\"My"\"Full"\"Path"\*.bak) DO DEL %%V
Hope this helps,
Henrique
yes it works thanks a lot but i want to know what is the code need to be writtrn to automatically load the files in the same loaction of bat file
hmsilva
You're welcome, nabsterhema!
I do not deal with batch files for some time, but possibly something like this will do the trick
cd/%~dp0
Hope this helps,
Henrique
yes thanks it works
hmsilva
Glad I could help
Henrique
