why is the next code running on only one line?
I wanted four lines will be drawn in order. but I can't.... ( I want to draw a rectangle by only putting values not by shaping directly) please help me.
(defun c:myrec ()
(setq a (getint "\n width:"))
(setq b (getint "\n height:"))
(command "line" (list 0 0) (list a 0)) ;line 1
(command "line" (list a 0) (list a b)) ;line 2
(command "line" (list a b) (list 0 b)) ;line 3
(command "line" (list 0 b) (list 0 0)) ;line 4
Accepted solutions (3)
doaiena
You need to end the "line" command like this:
(command "line" (list 0 0) (list a 0) "")
It's also a good idea to turn off snaps, because they might cause problems.
_gile
You can also specify succesively all the points in the same (command "_line" ...) expression.
As said @doaiena you should take care of possible running osnaps. This can be done using the "NONE" osnap to deactivate all running osnaps before specifying each point.
You can end the command by using the "_close" option, this avoid specifying the first point as last point.
Last, it's a good practice to use global command names (and option names) so the your code works whatever the culture version of AutoCAD (this is simply done by prefixing the English command names with an underscore).
  (command "_line"			; global command name (prefixed with underscore)
	   "_non"			; none osnap
	   (list 0 0)
	   "_non"			; none osnap
	   (list a 0)			; line 1
	   "_non"			; none osnap
	   (list a b)			; line 2
	   "_non"			; none osnap
	   (list 0 b)			; line 3
	   "_close"			; line 4
Gilles Chanteau
GileCAD
GitHub
Sea-Haven
2 suggestions
1 use Pline
2 use Rectang only need the two corners.
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(command "pline" (list 0 0) (list a 0) (list a b) (list 0 b) "c")
(setvar 'osmode oldsnap)
(setvar 'osmode 0)
(command "rectang" (list 0 0) (list a b))
Need to add pick point again 2 ways add to x y values or move "last"
An extra
; simple draw a box and dimension it
; By Alan H March 2019
' info@alanh.com.au
