while loop help
while loop help
Message 1 of 13
while loop help
So currently I am attempting to create a routine to allow the user to automatically draw the walls for a floorplan with the option of after every wall drawn the user can choose to draw another one and this will continue until the user says no. I have started the routine, but am a little stuck as i cannot find anywhere what the arguments for the offset command are. I also cannot figure out how I get the line to draw the direction i want it to go
I have the bare bones of the routine (Yes I know I have arguments missing from command line) (at some point in the routine i'm going to add a fillet command for the inner walls)
thanks in advanceSmiley Wink
; The purpose of this program is to allow the user to enter/pick dimensions of  a floor plan
; and have it drawn for them
(defun C:wall(/ choice ip Lwall ang off)
	(setq choice "Yes")
	(while (= choice "Yes")
		(setq ip (getpoint "\nPlease select an insertion point: "))
		(setq Lwall (getdist "\nPlease enter/choose the distance for the wall: "))
		(setq ang (getangle "\nWhat angle would you like the wall to be at?: "))
		(command "Line" )
		(setq off (getdist "\nHow thick is this wall?: "))
		(command "_offset" off )
		(initget 1 "Yes No")
		(setq choice (getkword "\nWould you like to draw another wall? [Yes/No]: "))
Replies (12)
Message 2 of 13
Ranjit_Singh
One option for example.
(defun c:wall  (/ choice ip lwall ang off)
 (setq choice "Yes")
  (setq lwall (getdist "\nPlease enter/choose the distance for the wall: ")); don't think this is needed since you draw the line anways
  (command "Line" pause pause "") ; no need to get distance at line 5 because you draw the line here
  (command "_offset")
  (while (> (getvar 'cmdactive) 0) (command pause))
  (setq choice (getkword "\nWould you like to draw another wall? [Yes/No]: "))))
Another option to pick the point. You can play with nomutt and cmdecho to suppress any prompts
(defun c:somefunc ()
(command "._line" pause pause "")
(command "._offset" (getreal "\nSpecify offset distance: ") (entlast) pause ""))
Message 3 of 13
Thankyou so much i always forget that when i do command "line" that it runs it like it would in cad and it already has user dialogue. Is there a way that I can make it ask How long do you desire the wall to be or something similar instead of the normal line prompt? I wouldn't need the angle prompt either since that is part of the line command correct? Also what is the purpose of the second while loop? (just for knowledge sake)
Message 4 of 13
weird i had a reply and it got deleted. in theory i wouldn't need the getangle either then correct? also is there a way to modify the line and offset command window prompts to say what i have in my code? lastly what is the second while loop for? (still learning)
Message 5 of 13
ВeekeeCZ
Make it user friendly...
;don't do this
(setq choice "Yes")
  ; stuff
; do this, natural way
(while (setq ip (getpoint "\nPlease select an insertion point <no more walls>: "))
   ; stuff
Message 6 of 13
wouldn't the second option be stuck in an infinite loop unless you hit esc?
Message 7 of 13
ВeekeeCZ
Try to type (getpoint "Now hit <enter>: ") into command line and hit ENTER.
Message 8 of 13
"Point or option keyword required."
^^^ My code goes to this after it hits the offset command section
Message 9 of 13
Ranjit_Singh
If you have specified any option keywords calling initget before the getpoint function, then it throws that error unless you pass a point or one of the keywords.
Message 10 of 13
This is what I currently have, also the typical command window prompts for line and offset are non-existent. also the offset command does not run
; Garrett Ford 6/22/17
(defun C:fp(/ choice)
	(setq choice "Yes")
		(princ "\nPick Points/Enter Length of the wall: ")
		(command "Line" pause pause)
		(princ "\nOffset your Wall: ")
		(command "_offset")
		(setvar 'cmdactive 0)
Message 11 of 13
Ranjit_Singh
	(setq choice "Yes")
		(command "Line" pause pause ""); "" needed to end the command
		(command "_offset")
		(setvar 'cmdactive 0);cmdactive is a read-only variable. Cannot use setvar. You don't need this line anyways
Try below
 (setq choice "Yes")
Message 12 of 13
Thankyou so much Smiley Very Happy
Message 13 of 13
ВeekeeCZ
This is what I've meant. Finish by enter.
(defun c:Wall (/ ip off)
  (initget 6)
  (setq off (getreal "\nWall offset: "))
  (while (setq ip (getpoint (strcat "\nStart draw a wall with offset of " (rtos off 2 1) (if ip " <done>" "") ": ")))
    (command "_.LINE" "_none" ip PAUSE ""
             "_.OFFSET" off (entlast) "_none" PAUSE ""))
  (princ)
