while click point txt lsp
helper guys. I am learning lsp and making easy code.
(defun c:n (/ no siz pt)
(setq alf '("a20" "a75" "b40" "c30" "d10"))
(setq no 1)
(setq siz (* 3 (getvar "dimscale")))
(while (setq pt (getpoint "pick point :"))
(command "text" "m" pt siz 0 alf)
(setq no (1+ no))
(princ)
I made it but not working. some help please
if one click ---> a20
if 3 click  --->  a20 a75 b40
if 5 click --->  a20 a75 b40 c30 d10
I want to do this. thank you guys
_Tharwat
Something like this?
(defun c:test (/ txt siz alf pt)
(setq txt "")
(foreach str alf
  (if (setq pt (getpoint "pick point :"))
    (command "text" "m" "_non" pt siz 0 (setq txt (strcat txt " " str)))
(princ)
dbhunia
Like this........
(defun c:N (/ txt siz alf pt)
(setq txt "")
(foreach st alf
(command "text" "m" pt siz 0 (setq txt (strcat txt " " st)))
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Kent1Cooper
Assuming that you mean to apply the separate text strings in the list individually, one per picked location, and not as one string with spaces as other have assumed, try this:
(defun c:n (/ alf no siz pt)
  (setq no 0)
  (while
    (and
      (< no (length alf)); still any left
    ); and
    (command "text" "m" pt siz 0 (nth no alf))
    (setq no (1+ no))
(princ)
Kent Cooper, AIA
always thank you
sooooo good
dbhunia
Hi Union,
I am glad you got your solution.......
But in your query you asked you want something like that.......
So accordingly I & @_Tharwat changes your program ......... for your requirement....
Debashis Bhunia
