While Break out Problem
richie_hodgson
Message 1 of 8
richie_hodgson
Having not a lot of fun trying to break out of a while loop, I have tried a couple of IF alternatives but to no avail I am probably missing something but now need a little input to get this thing moving.
(defun c:plpc (/ cursnap offset grade deltay pt1 pt2)
(setq cursnap (getvar "osmode"))
(setq pt1 (getpoint "\nPick Start Point :"))
(setvar "osmode" 0)
(setq offset 1)
(while not(= "" offset)
(setq offset (getreal "\nType Offset:"))
; (if not (= "" offset)
;(progn
(setq grade (getreal "\nType Percentage Grade:"))
(setq deltay (* offset (/ grade 100)))
(setq pt2 (mapcar '+ pt1 (List offset deltay 0)))
(command "_pline" pt1 pt2 "")
(setq pt1 pt2)
(setvar "osmode" cursnap)
Hope you can help.
Richie
Replies (7)
Message 2 of 8
cadffm
(defun c:plpc (/ offset grade deltay pt1 pt2)
  (setvar 'OSNAPCOORD 1)
  (if (setq pt1 (getpoint "\nPick Start Point :"))
      (while (and
	       (setq offset (getreal "\nType Offset: ")) ; thats not the autocad usual syntax / keyword INITGET
	       (setq grade  (getreal "\nType Percentage Grade: "))
) (setq deltay (* offset (/ grade 100))) (setq pt2 (mapcar '+ pt1 (list offset deltay 0))) (command "_.pline" pt1 pt2 "") (setq pt1 pt2) ) ) (princ) )
Sebastian
Message 3 of 8
john.uhden
It's probably just me, but I would get rid of the word "Type."
Until I saw (getreal), I thought you were asking for some type of offset, like maybe oblique, symmetric, octal, or other such terms that sound technically exotic.
John F. Uhden
Message 4 of 8
richie_hodgson
H John
The offset is in fact the horizontal distance for this example, the code could be adapted for slope distance but it suits my purpose.
Regards
RIchie
Richie
Message 5 of 8
ВeekeeCZ
Just you to know. NOT it the function and needs to be placed within parenthesis. (while (not (= ...
Message 6 of 8
john.uhden
Thank you for that explanation. My attempts at humor are often elusive.
John F. Uhden
Message 7 of 8
Kent1Cooper
Just a suggested different way, with less code and several fewer variables, and resulting in a single  Polyline profile rather than a batch of contiguous but separate single-segment ones [which, in that case, may as well just be Lines]:
(defun c:plpc (/ offset grade)
  (command "_pline" pause)
  (while
    (and
      (setq offset (getreal "\nOffset distance to right: "))
      (setq grade (getreal "\nPercentage Grade: "))
    ); and
    (command "_none" (mapcar '+ (getvar 'lastpoint) (list offset (* offset (/ grade 100)))))
  ); while
  (command ""); finish Pline
); defun
Kent Cooper, AIA
Message 8 of 8
richie_hodgson
Thanks very much for that. I was looking for a simple way to do this with a Pline command. I am back at work today after the Christmas break so thinking mode is not yet entirely engaged. Will look at the code a bit more closely when clever mode turns on.......
Regards
Richie
Richie
