When 2d point equal 3d point?
Kirillspec
Kirillspec
I have a code in which first i get lwpolyline from drawing
(setq pl (entget (car (entsel)))
then i get endpoint of this lwpolyline
(setq plbbb (cdr (assoc 10 (reverse pl))))
then i have in my drawing block with insertion point at the end of my polyline, and i want to obtain a selection set with this block only
(setq ssblock (ssget "_X" (list  (cons 10 plbbb) (cons 0 "INSERT"))))
The question is - why this ssget function is worked and gives me a selection set with this block although end point of lwpolyline is 2d (without z) and insertion point of block is 3d (with z = 0). ?
If i want compare endpoint of lwpolyline and insertion point of block, the =, eq and equal returns nil
TomBeauford
lwpolyline has an Elevation value in properties. It's constant for every vertex lwpolyline unlike a 3dpolyline but it has Elevation.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Kirillspec
Yes, but the question is why filter (cons 10 plbbb) where plbbb has only x and y coordinates works for block with insertion point which has x,y and z coordinates?
ВeekeeCZ
I think that where the point definition is required and a 2D point is accepted, then it is implicitly assumed that the omitted Z is 0.
While we don't see into the ssget definition.... it could be similar as
(entmakex (list (cons 0 "CIRCLE") (cons 10 '(0 0)) (cons 40 4))))
Kirillspec
OK, Thank you!
Sea-Haven
If you want 1 block dont worry about "X", (ssget pt)  I have found reliable
