Visual LISP, AutoLISP and General Customization
🔊 - Whats your thoughts on AutoLISP in AutoCAD LT 2024?
146 REPLIES 146
Message 1 of 147
handjonathan
18592 Views, 146 Replies
Hello, AutoCAD community,
The AutoCAD team wants to hear your impressions of AutoLISP, specifically around its availability in the 2024 release of AutoCAD LT.
Which routines are you most excited to use? Let us know in the comments below!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
146 REPLIES 146
Message 81 of 147
HE-MJJ
in reply to: paullimapa
Other then the previous result under AutoCAD full version I showed you, I now get a nil result under AutoCAD LT. So it's not solved yet. Maybe AutoCAD LT does not swallow certain VLAX functions? The problem now is that under AutoCAD LT I do not have VLIDE to check where it goes wrong.
Message 82 of 147
paullimapa
in reply to: HE-MJJ
You can always copy and paste the code a line at a time to LT command line and troubleshoot the old fashion way
Paul Li
IT Specialist
@The Office
Message 83 of 147
HE-MJJ
Yes, but very time consuming…
Message 84 of 147
paullimapa
in reply to: HE-MJJ
This function not supported in LT. It’s time for you to go full Autocad
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-D5A6811A-F110-49DD-AF83-1F64773D7DC1
Paul Li
IT Specialist
@The Office
Message 85 of 147
HE-MJJ
in reply to: handjonathan
We already have 12 full versions. I was hoping to make (all) my code work under LT so that we can switch to the LT versions in the future . LT is 0,25% the price of a full version.
Message 86 of 147
paullimapa
in reply to: HE-MJJ
No can do unfortunately
Paul Li
IT Specialist
@The Office
Message 87 of 147
Sea-Haven
in reply to: HE-MJJ
Look at Bricscad the basic version has lisp, I ahve the next Version Pro, so can not comment about what does not work. You can download a trial version.
Message 88 of 147
vladimir_michl
in reply to: HE-MJJ
This can be used as dos_splitpath:
(defun dos_splitpath (path / spl ad)
(setq path (vl-string-trim " " path))
(if (or (= (substr path (strlen path)) "/")(= (substr path (strlen path)) "\\"))(setq path (strcat path "a.a") ad T))
(setq spl (fnsplitl (strcase path))) ; ("C:\\ACAD\\SubD\\" "abc" ".txt")
(if (= (substr path 2 1) ":")
(setq spl (cons (substr (car spl) 1 2) (cons (substr (car spl) 3) (cdr spl))))
(setq spl (cons "" (cons (substr (car spl) 3) (cdr spl))))
(if ad (setq spl (list (car spl)(cadr spl) "" "")))
spl
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Message 89 of 147
HE-MJJ
in reply to: Sea-Haven
I know, we want to stick with AutoCAD. Thanks. ; )
Message 90 of 147
HE-MJJ
in reply to: vladimir_michl
This one worked for me. Thank you very much! :thumbs_up:
Message 91 of 147
HE-MJJ
I want to orderly disable commands in I havn't fixed yet for LT.
Acadver in AutoCAD LT and Full version both result in "24.3s (LMS Tech)".
How can I determin the AutoCAD LT version in lisp?
Message 92 of 147
vladimir_michl
in reply to: HE-MJJ
I am using:
(defun isinLT ( / )(= (strcase (getvar "PROGRAM") T) "acadlt"))
(getvar "VERSION")
Message 93 of 147
HE-MJJ
 I would have expected Acadver to give a different result. But this works. Simple, thanks. : )
Message 94 of 147
HE-MJJ
Do you perhaps also have one to replace dos_cdate?
(dos_cdate "%y%m%d %H.%Mu") Results in "240312 13.15u"
I can use: (jtoc (getvar "date")) which results in (2024 3 12 13 19 21.0)
But then I need to convert that to the result of dos_cdate.
Message 95 of 147
HE-MJJ
in reply to: HE-MJJ
To get the same result as (dos_cdate "%y%m%d %H.%Mu")
I created:
(defun dos-cdate ( / ttt tt1 )
(setq ttt (jtoc (getvar "date")))
(strcat (substr (rtos (car ttt)) 3 2)
(if (= (strlen (setq tt1 (rtos (nth 1 ttt)))) 1) (strcat "0" tt1) tt1)
(if (= (strlen (setq tt1 (rtos (nth 2 ttt)))) 1) (strcat "0" tt1) tt1) " "
(if (= (strlen (setq tt1 (rtos (nth 3 ttt)))) 1) (strcat "0" tt1) tt1) "."
(if (= (strlen (setq tt1 (rtos (nth 4 ttt)))) 1) (strcat "0" tt1) tt1) "u"
But I also need to replace:
(dos_cdate "%W")
(dos_cdate "%Y%m%d")
(dos_cdate "%y%m%d%H%m%S")
(dos_cdate "%d-%m-%y / %H.%Mu")
(dos_cdate "%d%m%y %H.%Mu \(week ")
(dos_cdate "%d-%m-%Y %H.%Mu \(week %W\)")
Message 96 of 147
vladimir_michl
in reply to: HE-MJJ
If you don't need exactly same formatting codes, you can use e.g.
(menucmd "M=$(edtime,$(getvar,date),YY MO DD HH:MM)")
(menucmd "M=$(edtime,$(getvar,date),YY-MO-DD H:MM:ss \",\" DDDD)")
All date calculations will be more complicated.
Vladimír Michl, www.arkance-systems.cz  -  www.cadforum.cz
Message 97 of 147
HE-MJJ
Thanks! This is better. I would not expect this to be possible with menucmd.
Do you also know how to obtain the week number? It doesn't seem to be possible with menucmd.
Message 98 of 147
Sea-Haven
in reply to: HE-MJJ
Did you google ? Why week number any way if you have a date I am sure somewhere there is a formula.
Need to take into account Feb 28 or 29. Make a list of number of days per month (31 29 31 ......
Message 99 of 147
vladimir_michl
in reply to: HE-MJJ
No, this is not possible with edtime. This would require those separate calculations - not complicated ones, but not to be just expressed as a formatting code. See e.g. the Lee Mac's code for the weekday and weeknumber:
https://www.cadforum.cz/en/how-to-get-week-day-and-week-number-from-a-given-date-tip14063
Message 100 of 147
HE-MJJ
Thanks! Replaced dos_cdate.
I did eventually find the getweek function but LM:weeknumber is much shorter. Better?
; (getweek (atoi (menucmd "M=$(edtime,$(getvar,date),YYYYMODD)")))
(defun getweek (dt / date year month day hour minute year# month# m DayNumber Weekday Jan1Weekday weeknr)
(defun LeapYear (Y) (if (or (and (= (rem Y 4) 0)(/= (rem Y 100) 0))(= (rem Y 400) 0)) T nil))
(setq date (rtos dt 2 4) year (substr date 1 4) month (substr date 5 2) day (substr date 7 2) hour (substr date 10 2) minute (substr date 12 2) year# (atoi year) month# (atoi month) M (1- month#) DayNumber (atoi day))
(if (= (setq Weekday (jtow (ctoj year# month# DayNumber 0 0 0))) 0)(setq Weekday 7))
(setq Weekday$ (nth (1- Weekday) '("Maandag" "Dinsdag" "Woensdag" "Donderdag" "Vrijdag" "Zaterdag" "Zondag")))
(if (= (setq Jan1Weekday (jtow (ctoj year# 1 1 0 0 0))) 0)(setq Jan1Weekday 7))
(while (> M 0) (setq DayNumber (+ DayNumber (cond ((member M '(4 6 9 11)) 30) ((= M 2)(if (LeapYear year#) 29 28)) (T 31))) M (1- M)))
(cond ((and (<= DayNumber (- 8 Jan1Weekday))(> Jan1Weekday 4)) (setq year$ (strcat " "(itoa (1- year#)))) (if (or (= Jan1Weekday 5)(and (= Jan1Weekday 6)(LeapYear (1- Year#)))) (setq weeknr 53) (setq weeknr 52)))
((< (- (if (LeapYear year#) 366 365) DayNumber)(- 4 Weekday)) (setq year$ (strcat " "(itoa (1+ year#))) weeknr 1))
(T (setq year$ "") (setq weeknr (fix (/ (+ DayNumber (- 7 Weekday)(1- Jan1Weekday)) 7.0))) (if (> Jan1Weekday 4)(setq weeknr (1- weeknr))))
) ; (strcat year "-" month "-" day " " hour ":" minute "u (Week "(itoa weeknr) year$ ") " Weekday$)
(strcat (itoa weeknr) year$)
AutoCAD Inside the Factory
