What i Mistake Mark dimension insertion point ?
jaimuthu
Message 1 of 11
jaimuthu
(defun c:DimJaiBasePointToInsertion ( / basePt selSet blkName blkObj blkPt dimOffset dimSpacing currentPt i count)
  (setq dimSpacing 0.5)
  (setq basePt (getpoint "\nSelect base point: "))
  (setq blkName "jai")
  (setq selSet (ssget '((0 . "INSERT") (2 . "jai"))))
  (if selSet
    (progn
      (setq dimOffset 0.0)
      (setq count (sslength selSet))
      (setq i 0)
      (while (< i count)
        (setq blkObj (ssname selSet i))
        (setq blkPt (cdr (assoc 10 (entget blkObj))))
        (if blkPt
          (progn
            (setq currentPt (list (car basePt) (+ (cadr basePt) dimOffset) (caddr basePt)))
            (command "._dimlinear" currentPt blkPt)
            (setq dimOffset (+ dimOffset dimSpacing))
          (princ "\nInvalid block point encountered.")
        (setq i (1+ i))
    (princ "\nNo blocks named 'jai' found.")
  (princ)
i want mark dimension in block name having the name of "jai" but its mark only some blocks  here i attached dwg file is what i need
Accepted solutions (4)
Replies (10)
Message 2 of 11
ВeekeeCZ
You need to add another loop to gather all the x-coords and sort the blocks by them.
Here is example of sort func
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-F3B27BD2-27FA-4185-B22C-85509175C171
Message 3 of 11
-didier-
Bonjour @jaimuthu
here’s what I propose with a sorting of the increasing X as suggested @ВeekeeCZ
Amicalement
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/what-i-mistake-mark-dimension-insertion-point/m-p/13085107#M473004
question sur les dim linéaires
je propose ça avec un tri des points de ss  avec les x croissants
(defun c:dimjai ( / basept lst n offset ss)
    (setq offset 0.2)
    (setq ss (ssget '((0 . "INSERT") (2 . "jai"))))
    (repeat (setq n (sslength ss))
        (setq lst (cons (list
                        (car (cdr (assoc 10 (entget (ssname ss (setq n (1- n)))))))
                        (cadr basept))
                    lst)
    (setq n 0)
    (setq lst (vl-sort lst (function (lambda (e1 e2) (< (car e1) (car e2))))))
    (foreach item lst
        (command "._dimlinear" basept item (list (car basept) (+ (cadr basept) (* offset (setq n (1+ n))))))
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 4 of 11
Moshe-A
@jaimuthu hi,
you need to sort blocks position before adding dimensions
call the following function with BasePt and the selection set of blocks and it will return you with this list sorted by the distance from BasePt
'(((dist1 '(x y z)) (dist2 '(x y z)) ...)
enjoy
Moshe
(defun dsort (base ss)
 (vl-sort
  (mapcar
   (function
     (lambda (elist / p0)
      (setq p0 (list (car (cdr (assoc '10 elist))) (cadr base)))
      (cons (distance base p0) (list (list p0)))
   (mapcar 'entget (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  (function (lambda (e0 e1) (< (car e0) (car e1))))
Message 5 of 11
jaimuthu
it is possible create Vertical Dimension in same way ?
Message 6 of 11
Moshe-A
@jaimuthu ,
here is a fix to (dsort) function
a 3th argument direction is added:
if you pass 'HOR, you will get list for horizontal dimension
if you pass 'VER, you will get list for vertical dimension
enjoy
moshe
(defun dsort (base ss direction)
 (vl-sort
  (mapcar
   (function
      (if (eq dir 'HOR)
       (setq p0 (list (car base) (cadr (cdr (assoc '10 elist)))))
Message 7 of 11
jaimuthu
its not work
Message 8 of 11
Moshe-A
It is not working does not help me to understand.
Post the code you are running
Message 9 of 11
Moshe-A
@jaimuthu ,
check this
works only at 0.0 or 90.0 angle
(defun c:DimJaiBasePointToInsertion ( / askOrient dsort ; local functions
				        dimSpacing basePt orient selSet points^ i pt0 pt1)
 (defun askOrient (def / ask)
  (initget "Horizontal Vertical")
  (setq ask (getkword (strcat "\nDimension orientation [Horizontal/Vertical] <" def ">: ")))
  (cond
   ((not ask)
    (if (eq def "Horizontal") 0.0 (/ pi 2))
   ((eq ask "Horizontal")
    0.0
   ( t (/ pi 2))
 ); askOrient
 ; return list of dimension points
 (defun dsort (base ss ang)
  (mapcar
   (function
    (lambda (item)
     (caadr item)
    ); lambda
   ); function
   (vl-sort
    (mapcar
     (function
       (if (eq ang 0.0)
       ); if
      ); lambda
     ); function
    ); mapcar
   ); vl-sort
  ); mapcar
 ); dsort
 ; here start c:DimJaiBasePointToInsertion
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (setq dimSpacing 0.25) ; const
 (if (and
       (setq basePt (getpoint "\nSpecify base point: "))
       (setq orient (askOrient "Horizontal"))
       (setq selSet (ssget '((0 . "insert") (2 . "jai"))))
  (progn
   (setq points^ (dsort basePt selSet orient))
   (setq i 0)
   (setq pt0 (car points^))
   (foreach pt1 (cdr points^)
    (if (= orient 0.0)
     (command "._dimlinear" pt0 pt1 (list (car pt1) (+ (cadr basePt) (* dimSpacing (setq i (1+ i))))))
     (command "._dimlinear" pt0 pt1 (list (- (car pt1) (* dimSpacing (setq i (1+ i)))) (cadr pt1)))
    ); if
    (setq item0 item1)
   ); foreach
  ); progn
 ); if
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
Message 10 of 11
jaimuthu
Its work good Thanks for Your Response
Message 11 of 11
Moshe-A
fixed a bug 🤣
