Wcmatch wtih wildcards
Hello all,
Thank you for considering to answer my question here.
So i have many variations of "structure IDs" this one in particular is "stk 55[3C] P1"
I have the structure of a program to go search all cogo point description and find my structure number ("stk 55[3C] P1")
However, I am having issues on the matching part.
The names varry and could have [] or - or _ so i tried using LeeMacs Code but cant get it to work.
I have attached the code i have been working on as well- its a little messy as i am still working on it
http://www.lee-mac.com/escapewildcards.html - here is the like to lee macs code i waas trying to use
;; Escape Wildcards  -  Lee Mac
;; Escapes wildcard special characters in a supplied string
(defun LM:escapewildcards ( str )
    (if (wcmatch str "*[-#@.*?~`[`,]*,*`]*")
        (if (wcmatch str "[-#@.*?~`[`,]*,`]*")
            (strcat "`" (substr str 1 1) (LM:escapewildcards (substr str 2)))
            (strcat     (substr str 1 1) (LM:escapewildcards (substr str 2)))
        str
(LM:escapewildcards "stk 55[3C] P1" )
(WCMATCH  "stk 55[3C] P1"(LM:escapewildcards "55[3C]"))
Escentally would this not work for matching up with any string to any pattern?
what am i doing wrong and what could be the solution?
hak_vz
Try this
(wcmatch  "stk 55[3C] P1" (strcat "*" (LM:escapewildcards "55[3C]") "*"))
Also use STRCASE function to change letter case since WCMATCH comparison is case-sensitive, so uppercase and lowercase characters must match.
Miljenko Hatlak
Thats amazing, it works exactly how I anticipated!
Thank you so much for your help!
