WBlock Method
WBlock Method
WBlock Method
I am using the following query link:
Help AutoCAD - WBlock Method (ActiveX)
But the routine example lisp does not work.
The file is not being created in the directory.
What can it be?
Shneuph
I understand you are using the VisualLISP sample code from that link?  How did you enter your path at the end for the wblocked file?
EDIT:
It also did not save a file for me in C:\Autodesk\  But when I changed the path to T:\...\ it worked.  Probably a folder permissions issue.  Try saving to a folder like My Documents.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
I've done several road tests
I tested even create a folder in the location of the above example , still does not work.
I'm trying the same is in the same example .
Permissions issue.
Thank you!
