Want calculate z value from two points and get mid point with 3d value
Calculate z value from given two 3d point and and get mid of these point with z value
As show in jpg. It's show as side view
cadffm
ronjonp
Many ways to do this but as the benchmark shows, POLAR is the fastest 🙂
(setq p0 (getpoint)
      p1 (getpoint)
(benchmark '((polar p0 (angle p0 p1) (/ (distance p0 p1) 2.))
	     (mapcar '/ (mapcar '+ p0 p1) '(2. 2. 2.))
	     (mapcar '(lambda (a b) (/ (+ a b) 2.)) p0 p1)
	     (list
	      (/ (+ (car p0) (car p1)) 2.)
	      (/ (+ (cadr p0) (cadr p1)) 2.)
	      (/ (+ (caddr p0) (caddr p1)) 2.)
;;;Benchmarking .................Elapsed milliseconds / relative speed for 16384 iteration(s):
;;;    (POLAR P0 (ANGLE P0 P1) (/ (DISTANCE...).....1719 / 2.15 <fastest>
;;;    (LIST (/ (+ (CAR P0) (CAR P1)) 2.0) ...).....2469 / 1.50
;;;    (MAPCAR (QUOTE (LAMBDA (A B) (/ (+ A...).....3125 / 1.18
;;;    (MAPCAR (QUOTE /) (MAPCAR (QUOTE +) ...).....3703 / 1.00 <slowest>
MunteanStefan
Careful with polar function, it works only in 2D.
Also, the anlge function will project the 3D points into xOy plan
_$ (setq p0 '(0.0 0.0 100.0) p1 '(50.0 80.0 150.0))
_$ (polar p0 (angle p0 p1) (/ (distance p0 p1) 2.0))  ->  (28.2942 45.2707 100.0)
_$ (polar p1 (angle p1 p0) (/ (distance p1 p0) 2.0))  ->  (21.7058 34.7293 150.0)
ronjonp
Oops! You are totally correct. Learned something new today 🙂
Kent1Cooper
[Written while others were posting with the same thought, but hey -- color and boldface and italics are always impactful....]
HOWEVER, (angle) operates only in 2D.  [Maybe that's why it's faster!]  The AutoLisp Reference entry for (angle) says:
  If 3D points are supplied, they are projected onto the current construction plane.
So:
  (setq p0 '(0 0 0) p1 '(2 2 2))
Halfway between them should be '(1 1 1), but:
returns:
  (1.22474 1.22474 0.0)
Whereas:
  (mapcar '/ (mapcar '+ p0 p1) '(2 2 2))
returns:
  (1.0 1.0 1.0)
Kent Cooper, AIA
