Waiting for command to finish in AutoLISP
326047736
326047736
Hello everyone.
I'm trying to wait for the boundary command to finish in AutoLISP. So I tried the code below:
(command "_.-boundary")
(while (> (getvar 'cmdactive) 0) (command pause))
(command "move" (entlast))
But I mysteriously can't select all the options of the command:
So I changed a little bit of the code:
(while (= (getvar "CMDNAMES") "boundary") (command pause))
(print "Hello!")
AutoLISP didn't "wait" for the command to finish and printed "Hello!" on the console directly:
What should I have a try next?
Any reply might be helpful. Thanks!
ВeekeeCZ
Your comparison fails. See HERE
It seems that 'cmdactive method works fine for me.
You can also try (command-s "-boundary") method if you have acad 2016+
Thanks a lot! @ВeekeeCZ
Command-s works great (on AutoCAD 2020) and I should really check the comparison result first.😅
