VSCode error "queue can't hold so many messages". How do I enlarge capacity?
John_Shimkus
John_Shimkus
While debugging in VSCode my program stops running and shows this error, in VSCode, on a line of code, "the queue can't hold so many messages; you need to enlarge its capacity".
How do I "Enlarge its capacity"?
BTW, the program runs and finishes fine if I'm not debugging it.
LDShaw
Without knowing what you are working on or anything about your setup I can only take a stab at it.
Increase Debugger Timeout:
If the debugger is timing out, you can increase the timeout settings.
Add "timeout": 10000 (or a higher value) to your launch.json configuration under the specific debug configuration.
or look for Extension Conflicts: Some VSCode extensions might interfere with the debugging process. Disabling extensions temporarily can help identify if one of them is causing the issue.
My guess is it's in the extensions.
John_Shimkus
Thanks for the suggestions but unfortunately, they did not help.
I uninstalled all extensions except AutoLisp, error still occurs.
Tried to add the timeout value to my launch.json file but VSCode did not recognize "timeout" (see attached).
