vplayer lisp
vplayer lisp
vplayer lisp
hello guys. have a good day
(defun c:vpf ()
 (setvar   "cmdecho" 0)
   (if (= (tblsearch "layer" "xr-aa"))
    (command "vplayer" "f" "xr-aa" "c" "")
    (if (= (tblsearch "layer" "xre-bb"))
    (command "vplayer" "f" "xre-bb" "c" "")
(princ)
this lisp does not work. some help guys...
Satish_Rajdev
Try this:
(defun c:vpf (/ cm)
  (setq cm (getvar 'cmdecho))
(setvar "cmdecho" 0) (foreach x '("xr-aa" "xre-bb") ; <- Add your layer list here (if (tblsearch "layer" x) (command-s "vplayer" "f" x "c" "") ) ) (setvar "cmdecho" cm) (princ) )
Best Regards,
Satish Rajdev
REY Technologies | Linked IN | YouTube Channel
ВeekeeCZ
I would suggest to open the vplayer command, do all layers, then close the command. That way you'll create just one layer state for LAYERP.
(defun c:vpf (/ cm)
  (command "vplayer")                     ; open the command
      (command "f" x "c")))               ; process all layers
  (command "")                            ; close the command
  (princ)
dwattersAMXH5
you could also just set the layer list to a setq
so rather then
you could add this
(setq layers '(layer list here))
(foreach x '("xr-aa" "xre-bb") layers
if you planned to do anything else to that group of layers.
thank you all
