VLIDE cannot open acad.dce file - Why? Where?
hencoop
Advisor Advisor
hencoop
(findfile "acad.dce") returns nil
So, why can not AutoCAD open this file? Where is this file supposed to be created by Autodesk?
Henry C. Francis
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
DannyNL
Are we talking about .DCE or .DCL files?
Looking at the error message you post, I'm assuming you mean .DCL files and that you are trying to get a preview of your .DCL file in the Visual LISP editor (Tools->Interface Tools->Preview DCL in Editor).
Unfortunately to enable this you'll need to make sure you have write-access to the C:\Program File\Autodesk\AutoCAD 2017 folder as the Visual LISP Editor will try to create a temporary file on that location before showing the preview. AFAIK this is inherited from the past and hasn't been changed ever since, hence  the need for write-access at that location.
hencoop
The temporary DCL file $vld$.dcl gets created in that folder.  There is no problem there.  The ACAD.DCE file does not get created but I have no idea where it is trying to create it.  I thought AutoCAD creates it in the current drawing folder but apparently not.  I have no idea what folder I need to take ownership of and give write access to in order to solve this problem.
BTW, I am on a new Win10 system, i9-7900X @ 3.3GHz, 1TB M2 SSD, 32GB M2 Optane, 32GB 2666 System RAM
Not sure if any of that other than Win10 could affect this problem.
Henry C. Francis
