vlax-ename->vla-object (entlast)
robert06
Message 1 of 12
robert06
(setq D1 (/ (getdist) 2))
(setq O1 (entsel))
(setq S1 (getpoint))
(command "offset" "e" "n" D1 O1 S1 "")
(setq ob (entlast))
(setq obj (vlax-ename->vla-object (car ob)))
can't figure out, why entlast can't be turned to vla-object with this nor
(setq obj (vlax-ename->vla-object (entlast)))
if to select again with entsel, works
(setq obj (vlax-ename->vla-object (car (entsel)))
Replies (11)
Message 2 of 12
Sea-Haven
Works for me no idea why not for you. Do you have (vl-load-com) at start of code ?
offset etc
: (setq obj (vlax-ename->vla-object (entlast)))
#<VLA-OBJECT IAcadLine 0000000063D0F0E0>
Message 3 of 12
robert06
so the bug must be somewhere else, please see the whole lisp
(deleted in edit)
Message 4 of 12
john.uhden
@robert06
Is the object getting offset?
How about if O1 were (car (entsel))?
John F. Uhden
Message 5 of 12
robert06
O1 is object existing prior running the command.
telg is created from O1 by offset alright, this is the entlast object i can't select for further processing.
Message 6 of 12
paullimapa
try this instead of car:
(setq obj (vlax-ename->vla-object ob))
Paul Li
IT Specialist
@The Office
Message 7 of 12
robert06
Thank you @paullimapa , this solved it.
Message 8 of 12
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Message 9 of 12
robert06
As I understand with car  the object name is extracted to handle (to rename etc), but without the object itself.
Message 10 of 12
paullimapa
all depends on the lisp function you use to grab the entity
(entsel) for example will return a list with 2 elements: <entity name> being the first & coordinates being the 2nd.
So in this case you'll need (car) to extract just the 1st element which is the <entity name> to pass on to vlax function:
(vlax-ename->vla-object <entity name>)
but if you use (entlast) function then you only get back the <entity name> and not a list so there's no need to use (car) function when passing on to vlax function:
Paul Li
IT Specialist
@The Office
Message 11 of 12
robert06
Message 12 of 12
paullimapa
You are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
