vla-SaveAs with dialog box prompt
msarqui
msarqui
Hi guys,
I am wondering if would be possible to use (vla-SaveAs object FileName FileType) to save a file, but without the FileName FileType part. I mean, I would like to have the dialog box that prompt for a name and a location.
I am asking for vla-SaveAs because this will be inside a reactor and I think I can't use command.
Or maybe another approach?
Marcelo
dbroad
Dialogs are only good for interactive operations.  Interactive operations are not possible in a reactor.
Architect, Registered NC, VA, SC, & GA.
msarqui
I think I found a solution, if someone is looking at the same subject.
I did a search here and there and I put the pieces together:
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq path (getfiled "Save as" "" "dwg" 1)) (vla-SaveAs doc path)
And it is working for me.
Marcelo
