vla-put-TextOverride within a block
M2O
Message 1 of 1
M2O
I'm currently running into an issue while trying to do a dimension override within a block and I've made a very basic test scenario with an attached .dwg file with the block. The scenario is a block called "Test" which is a single line segment with one vertex at (0,0) and the other at (20,0). The code below adds a dimension in the "Test" block and overrides the text to include the string "<>\\XThis is a test override.". The issue is that this override does not appear in model space and is only visible within the block editor. I've tried as many ways as I can think of to try and update the block but nothing seems to be successful. I've tried doing a vla-regen (which is included in this code sample), using the REDRAW/REGENALL commands, and even doing WBLOCK and inserting it to a new drawing. Nothing seems to work which has lead me to here to see if anyone might have some additional knowledge on this issue. The only other case I could find regarding this issue was a post from 2019 here: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/dim-text-override-from-within-a-bloc... where the exact same issue was occurring and there wasn't an exact resolution for it.
(defun c:dim-override-test (/ ACAD_Object ACAD_Document ACAD_Blocks)
  (vl-load-com)
  (setq ACAD_Object (vlax-get-acad-object)
        ACAD_Document (vla-get-ActiveDocument ACAD_Object)
        ACAD_Blocks (vla-get-Blocks ACAD_Document)
  (vla-StartUndoMark ACAD_Document)
  (vla-put-TextOverride
    (vla-AddDimRotated
      (vla-item ACAD_Blocks
        (vla-get-effectivename
          (vlax-ename->vla-object
            (ssname (ssget "X" (list (cons 2 "Test"))) 0)
          );vlax-ename->vla-object
        );vla-get-effectivename
      );vla-item
    (vlax-3d-point 0 0 0)
    (vlax-3d-point 20 0 0)
    (vlax-3d-point 0 5 0)
    0
    );vla-AddDimRotated
  );vla-put-TextOverride
  (vla-Regen ACAD_Document acALLViewports)
  (vla-EndUndoMark ACAD_Document)
  (princ)
Replies (0)
