vla-insertblock not working
rajeshpatnaik2001
rajeshpatnaik2001
Hi
The following code works fine to insert a block.
(command "-insert" blk_name "0,0" "1" "1" "0")
I am trying to write the same in visual lisp using the following code.
(vla-insertblock (vla-get-modelspace(vla-get-ActiveDocument (vlax-get-Acad-Object))) blk_name (vlax-3d-point 0 0 0) 1 1 1 0)
But it is showing an error:
; error: lisp value has no coercion to VARIANT with this type: #<variant 8197 ...>
What is wrong with my code??
Thanks.
rajeshpatnaik2001
I found the issue, position of point and name of the block need to be interchanged.
The corrected code is
(vla-insertblock  (vla-get-modelspace(vla-get-ActiveDocument (vlax-get-Acad-Object))) (vlax-3d-point 0 0 0) blk_name 1 1 1 0)
