vla-InsertBlock always re-scale my blocks
jtm2020hyo
jtm2020hyo
I have no idea why, but vla-InsertBlock always re-scale my block per 1000 units.
I mean, I have my block in millimeters, I want to insert in a model space with meters units, then the block is inserted and re-scaled per 1000 units.
Here is the code:
  (setq blockRefObj (vla-InsertBlock modelSpace insertionPnt VarBlockName1 1 1 1 VarBlockRotation1))
Any idea how to fix this?
PD: attached block
Sea-Haven
If you mix dwg units expect that to happen, set a dwg to feet and see what happens.
Try resetting "insunit" to suit .
paullimapa
if you don't want to rescale but forced x y z scale as 1 then use command line insert like this:
(command"-insert" VarBlockName1 insertionPnt "1" "1" VarBlockRotation1)
Paul Li
IT Specialist
@The Office
Sea-Haven
If you insert a block/dwg into another dwg one has units set to mm and the other m then the insert is a factor of 0.001 even at scale = 1.
Yes have checked the dwg provided, 2 dwgs in mm and metre.
Worse is where a dwg has units set to feet and other is set to say metric m. Scale factor is 3.2808
