VLA-GET-HASATTRIBUTES does not work in P3D
Message 1 of 8
when I use a routine with VLA-GET-HASATTRIBUTES in ACAD it works.
When I use it in P3D it does not.
"; Fehler: ActiveX-Server gab folgenden Fehler zurück: unbekannter Name: HasAttributes"
( (VLAX-ENAME->VLA-OBJECT EntityName) works...)
Guido
Replies (7)
Message 2 of 8
JustOpie
Have you executed (vl-load-com) function?
Message 3 of 8
Hi
yes.
....( (VLAX-ENAME->VLA-OBJECT EntityName) works...)
Message 4 of 8
_Tharwat
Show the related codes to that function to check them out for you.
Message 5 of 8
here is that small routine
(and it works in normal ACAD)
(defun c:ba()
  	(setq ss (ssget))
  	(setq EntityName (ssname ss 0))
	(SETQ VLA_OBJECT (VLAX-ENAME->VLA-OBJECT EntityName))
  	(IF (AND
	      	(= (VLA-GET-HASATTRIBUTES VLA_OBJECT) :VLAX-TRUE)
      		(SAFEARRAY-VALUE (SETQ Attribute (VLAX-VARIANT-VALUE (VLA-GETATTRIBUTES VLA_OBJECT)))))
	  	(progn
		  	(FOREACH Tag (VLAX-SAFEARRAY->LIST Attribute);Attribs auslesen
			  	(print (strcat (VLA-GET-TAGSTRING Tag) ": " (VLA-GET-TEXTSTRING Tag)));TAG groß/klein beachten!!!!
Message 6 of 8
_Tharwat
Have a play with this:
(defun c:ba  (/ ss)
  (if (setq ss (ssget '((0 . "INSERT") (66 . 1))))
    (foreach tag  (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'getattributes)
      (print (strcat (vla-get-tagstring tag) ": " (vla-get-textstring tag)))
  (princ)
  ) (vl-load-com)
Message 7 of 8
OK, that's it
the
makes the difference.
But the error messages has confused me.
Message 8 of 8
_Tharwat
You are welcome - Happy to help.
