VL-sort help
VL-sort help
DC-MWA
VL-sort help
DC-MWA
Anybody know why this misses sheet "A0.00 - Title Sheet.dwg"
(setq dwgs (cdr (vl-sort (vl-remove-if-not
'(lambda (x) (wcmatch (strcase x) "A*.*.DWG"))
(vl-directory-files (getvar 'dwgprefix))
) ;_ vl-remove-if-not
) ;_ vl-sort
) ;_ setq
SAPER59
I tested with my own list  (I don't have your directory) and don't miss it
(setq ldir (list "A0.00 - Title Sheet.dwg"
"A1.00 - Title Sheet.dwg"
"A2.00 - Title Sheet.dwg"
"My dwg1.dwg"
"My dwg2.dwg"
Are you sure file name is that you wrote?
 It would be a good idea you update the list of your directory
SAPER59
Sorry I forgot, you have a CDR at the beginig and loose first element of result list
Kent1Cooper
(setq dwgs
  (cdr
    (vl-sort
      (vl-remove-if-not
    ) ;_ vl-sort
  ); cdr
) ;_ setq
If it "hits" other similar drawing names, it's probably because "A0.00..." surely comes up first in such a sorted list, and the (cdr) function removes the first item.
Kent Cooper, AIA
DC-MWA
Thank you.
