vl-remove-if confuse
thsa2501
Message 1 of 12
thsa2501
hi everyone
this code getting from lee mac website. which I redmarked is so confusing because this code is getting nill personally checked ((= (setq i (1+ i)) n) but the code is index 3 removing the 3rd no from the list. how it is possible?
n= index 3
l = (list 0 1 2 3 4)
result  = '(0 1 2 4) how?
(defun LM:RemoveNth ( n l / i )
(setq i -1)
(vl-remove-if '(lambda ( x ) (= (setq i (1+ i)) n)) l)
thanks advance to everyone for helping
Replies (11)
Message 2 of 12
Kent1Cooper
In the (nth) function for lists, and also in the (ssname) function for selection sets, the first item is index number 0.
Kent Cooper, AIA
Message 3 of 12
john.uhden
@thsa2501
Though I was not at all fond of him, his contributions were outstanding...
  ;; Tony Tanzillo (01-25-02)
  (defun cut_nth (lst pos / head)
     (repeat pos
         (setq head (cons (car lst) head)
               lst (cdr lst)
     (append (reverse head) (cdr lst))
;; where pos is 0 based just like nth
John F. Uhden
Message 4 of 12
ВeekeeCZ
@thsa2501 wrote:
hi everyone
n= index 3
(setq i -1)
How did you check it? Do you understand how vl-remove-if works? Do you understand how mapcar works? It's basically a loop. So once i is 3 so the comparison is T, it's removed.
Change the apostrophe ' to function and trace the code step-by-step, you'll see.
  (setq i -1)
  (vl-remove-if (function (lambda ( x ) (= (setq i (1+ i)) n))) l)
Message 5 of 12
martti.halminen
Another way of doing this:
(defun remove-nth (n lst)
  ;; removes the nth item of the list, numbering starts from zero
  (if (or (null lst)(minusp n)(> n (1-(length lst))))
      lst
      (remove-nth-int n lst)))
(defun remove-nth-int (n lst)
  ;; Internals of remove-nth
  (cond
    ((zerop n) (cdr lst))
    (T (cons (car lst)
             (remove-nth-int (1- n) (cdr lst))))))
Message 6 of 12
Sea-Haven
There is a sequence of list manipulation examples over at the swamp, look for the [Challenge] Axx posts multiple answers for this question.
AutoLISP (Vanilla / Visual) (theswamp.org)
Message 7 of 12
thsa2501
thank you so much for your reply @ВeekeeCZ
i know how mapcar works, but i don't know how works vl-remove-if that is so confusing for me.
i have a question about (= (setq i (1+ i)) n)
already the value set is (setq i -1) .
this is my point view.it becomes nil value (= (setq i (1+ -1(i value)) 3 (n-input from user)).it becomes (= 0 3)  this is not equal.isn't it?
(vl-remove-if nil '(0 1 2 3 4))
the final answer is '(0 1 2 3 4)).this is what i understood.
Message 8 of 12
ВeekeeCZ
No, vl-remove-if works in the same way as mapcar.
Applies a function to each member of the list. If the function returns nil, then leaves the member, otherwise, deletes the member from the list.
Say you have this:
l = (list 2 4 6 8 10)
n = 4
(vl-remove-if '(lambda ( x ) (= n x)) l)
So it goes
(= 4 2)? nil               at this point x=2, n=4, so lambda is (= 4 2)
(= 4 4)? True           at this point x=4, n=4, so lambda is (= 4 4)
(= 4 6)? nil
(= 4 8)? nil
(= 4 10)? nil
The result is '(2 6 8 10)
Now your func.
n = 4
i = -1
(= 0 4)? nil         (note: x=2 !!)
(= 1 4)? nil         (note: x=4 !!)
(= 2 4)?nil         (note: x=6 !!)
(= 3 4)? nil         (note: x=8 !!)
(= 4 4)? True         (note: x=10 !!)
The result is '(2 4 6 8 )
Message 9 of 12
thsa2501
thank you so much for your reply.
it is so nice example, but I want to know how its works "vl-remove-if" function with lambda.
Message 10 of 12
ВeekeeCZ
I've added bold expressions.
I would prefer you to think about it a bit and not reply based on the first impression in a matter of secs.
Message 11 of 12
thsa2501
hi @ВeekeeCZ
i almost understood. the last question don't be mind.
'(lambda ( x ) (= (setq i (1+ i)) n)) where is "x" inside the (setq i (1+ i)) becauce defined lambda (x)
(vl-remove-if '(lambda ( x ) (= n x)) l) i completely understood your function.
Message 12 of 12
thsa2501
kindly ignore last message @ВeekeeCZ
