(vl-catch-all-apply 'command (list pause))
mdhutchinson
Advisor Advisor
mdhutchinson
I have the following loop to run until the user is finished with the command. An <Enter> key works as I want.
(while (= (getvar "cmdactive") 1)
   (command pause)
... continue with more code
... however, quite often the user hit <esc> key instead.
Can't I trap for this - with something like the following?
   (vl-catch-all-error-p (vl-catch-all-apply 'command (list pause)))
Your thoughts?
hmsilva
Try
(vl-catch-all-error-p (vl-catch-all-apply 'vl-cmdf (list pause)))
Hope this helps,
Henrique
mdhutchinson
Yep... that works.
so does this...
(vl-catch-all-error-p (vl-catch-all-apply (function (lambda (x)(command pause))) (list nill)))
Your's is better.
Thanks.
hmsilva
@mdhutchinson wrote:
Yep... that works.
so does this...
Your's is better.
Thanks.
You're welcome, mdhutchinson
Glad I could help
Henrique
