Visual LISP Make Application Error
Hello.  I have written a lisp routine with a dialog box and am having problems using make application so I can distribute the routine without worrying about the DCL file.  I start the Make New Application Wizard and get to the point where I attach the LSP file.  I can select the LSP file I need and click on open.  As soon as I select open, the wizard window shuts down and I receive an error in the Visual LISP Console.
Does anyone know what might cause this type of error.  I do not get any errors when I check the code in the VLIDE and the routine loads and runs fine.  Thanks.
marko_ribar
Try to change name of VLX file - make it shorter... Also LSP and DCL should have shorter filenames...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Thank you marko_ribar.  That did the trick.  I tried several different options once I got it to work with VERY short file names.  The original LSP file name had a hyphen in it, so I tried it by taking out the hyphen.  That also worked.  Thank you again.  I don't think I would have ever found that out on my own.
