VIEWTWIST > 2 * pi ? Yep
JamesMaeding
Advisor Advisor
JamesMaeding
Just found a sheet where the viewtwist of a viewport was greater than 360 deg!
Command: (GETVAR "VIEWTWIST")
12.1987
 The number here is radians, so way more than 2 pi.
I assume negative values are also acceptable to a dwg.
The end result being all my functions that check viewtwist need to "normalize" to between 0 and 2pi.
Something new....
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
john.uhden
Yes, you can "normalize" the angle (ang) by (rem ang (* pi 2)).
John F. Uhden
SeeMSixty7
if you find that it is greater than PI, then simply use
(rem viewtwist (* 2 PI))
The result will be a value less than 2PI but represents the proper radian value.
Good luck
JamesMaeding
of course your code is one line and mine is like 7 🙂
SeeMSixty7
yes what @john.uhden said. LOL.
