Viewport Scale
Viewport Scale
msarqui
Message 1 of 18
Viewport Scale
msarqui
Hi guys,
I made this simple routine to set the scale in my dynamic scale block. I used some Lee Mac's routines for the dynamic block, so thanks to him for all the hard work.
I am having two problems, and your help will be very appreciated.
First problem: If the scale of the viewport is less than 10 (like 1, 2, 2.5, etc) the block does not change its scale. I tried but I did not found the way to solve this.
Second problem, If I have more than one viewport in the same layout, the block will be set to the scale of the first viewport drawn. So, I think in that case, it will be necessary to make a list with the viewports scales, and then compare the scales in that list. If they are different, (setq ss1 "INDIQUÉE") and (setq vis "INDIQUÉE"). If they are equals, take the scale value and put to ss1.
If you can help, or If you have a better way, I will be thankful. 🙂
See attached my scale block.
(defun c:VS (/ retab ss ss1)
(setq retab (getvar 'CTAB))
(foreach layout (layoutlist)
(setvar "ctab" layout)
(if	(and (= (getvar "tilemode") 0) (= (getvar "cvport") 1)
	(setq ss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 layout))))
	);and
	(setq ss1 (rtos (/ 1 (vla-get-CustomScale (vlax-ename->vla-object (ssname ss 0)))) 2 0))
);if
(cond
	((= (sslength ss) 1) (setq vis "AUCUNE") (MS:ChangeVisibility vis))	;Without viewport
	((> (sslength ss) 1)							;With viewport
	(cond
		((= ss1 "1") (setq vis "1:1") (MS:ChangeVisibility vis))	;Problem here
		((= ss1 "2") (setq vis "1:2") (MS:ChangeVisibility vis))	;Problem here
		((= ss1 "2.5") (setq vis "1:2.5") (MS:ChangeVisibility vis))	;Problem here
		((= ss1 "3") (setq vis "1:3") (MS:ChangeVisibility vis))	;Problem here
		((= ss1 "5") (setq vis "1:5") (MS:ChangeVisibility vis))	;Problem here
		((= ss1 "7.5") (setq vis "1:7.5") (MS:ChangeVisibility vis))	;Problem here
		((= ss1 "10") (setq vis "1:10")	(MS:ChangeVisibility vis))
		((= ss1 "15") (setq vis "1:15")	(MS:ChangeVisibility vis))
		((= ss1 "20") (setq vis "1:20") (MS:ChangeVisibility vis))
		((= ss1 "25") (setq vis "1:25") (MS:ChangeVisibility vis))
		((= ss1 "30") (setq vis "1:30")	(MS:ChangeVisibility vis))
		((= ss1 "40") (setq vis "1:40")	(MS:ChangeVisibility vis))
		((= ss1 "50") (setq vis "1:50")	(MS:ChangeVisibility vis))
		((= ss1 "75") (setq vis "1:75")	(MS:ChangeVisibility vis))
		((= ss1 "100") (setq vis "1:100") (MS:ChangeVisibility vis))
		((= ss1 "125") (setq vis "1:125") (MS:ChangeVisibility vis))
		((= ss1 "150") (setq vis "1:150") (MS:ChangeVisibility vis))
		((= ss1 "200") (setq vis "1:200") (MS:ChangeVisibility vis))
		((= ss1 "250") (setq vis "1:250") (MS:ChangeVisibility vis))
		((= ss1 "300") (setq vis "1:300") (MS:ChangeVisibility vis))
		((= ss1 "350") (setq vis "1:350") (MS:ChangeVisibility vis))
		((= ss1 "400") (setq vis "1:400") (MS:ChangeVisibility vis))
		((= ss1 "500") (setq vis "1:500") (MS:ChangeVisibility vis))
		((= ss1 "600") (setq vis "1:600") (MS:ChangeVisibility vis))
		((= ss1 "750") (setq vis "1:750") (MS:ChangeVisibility vis))
		((= ss1 "1000")	(setq vis "1:1000") (MS:ChangeVisibility vis))
		((= ss1 "2000")	(setq vis "1:2000") (MS:ChangeVisibility vis))
		((= ss1 "2500")	(setq vis "1:2500") (MS:ChangeVisibility vis))
	 );cond
);cond
);foreach
(setvar "ctab" retab)
(princ)
;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/changing-visibility-states-in-dynamic-block/td-p/5322263
(defun MS:ChangeVisibility (vis / blk idx obj sel )
(setq blk "Tx - Échelle Métrique - Français")
(if (setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat "`*U*," blk)) (cons 410 (getvar "CTAB")))))
(repeat (setq idx (sslength sel))
(if (= (strcase blk) (strcase (LM:blockname (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))))))
(LM:SetVisibilityState obj vis)
(princ)
;; Block Name - Lee Mac
;; Returns the true (effective) name of a supplied block reference
(defun LM:blockname ( obj )
(if (vlax-property-available-p obj 'effectivename)
(defun LM:blockname ( obj ) (vla-get-effectivename obj))
(defun LM:blockname ( obj ) (vla-get-name obj))
(LM:blockname obj)
;; Set Dynamic Block Visibility State - Lee Mac
;; Sets the Visibility Parameter of a Dynamic Block (if present) to a specific value (if allowed)
;; blk - [vla] VLA Dynamic Block Reference object
;; val - [str] Visibility State Parameter value
;; Returns: [str] New value of Visibility Parameter, else nil
(defun LM:SetVisibilityState ( blk val / vis )
(if
(and
(setq vis (LM:getvisibilityparametername blk))
(member (strcase val) (mapcar 'strcase (LM:getdynpropallowedvalues blk vis)))
(LM:setdynpropvalue blk vis val)
;; Set Dynamic Block Property Value - Lee Mac
;; Modifies the value of a Dynamic Block property (if present)
;; prp - [str] Dynamic Block property name (case-insensitive)
;; val - [any] New value for property
;; Returns: [any] New value if successful, else nil
(defun LM:setdynpropvalue ( blk prp val )
(setq prp (strcase prp))
(vl-some
'(lambda ( x )
(if (= prp (strcase (vla-get-propertyname x)))
(progn
(vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
(cond (val) (t))
(vlax-invoke blk 'getdynamicblockproperties)
;; Get Dynamic Block Property Allowed Values - Lee Mac
;; Returns the allowed values for a specific Dynamic Block property.
;; Returns: [lst] List of allowed values for property, else nil if no restrictions
(defun LM:getdynpropallowedvalues ( blk prp )
(vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'allowedvalues)))
;; Get Visibility Parameter Name - Lee Mac
;; Returns the name of the Visibility Parameter of a Dynamic Block (if present)
;; Returns: [str] Name of Visibility Parameter, else nil
(defun LM:getvisibilityparametername ( blk / vis )
(if
(and
(vlax-property-available-p blk 'effectivename)
(setq blk
(vla-item
(vla-get-blocks (vla-get-document blk))
(vla-get-effectivename blk)
(= :vlax-true (vla-get-isdynamicblock blk))
(= :vlax-true (vla-get-hasextensiondictionary blk))
(setq vis
(vl-some
'(lambda ( pair )
(if
(and
(= 360 (car pair))
(= "BLOCKVISIBILITYPARAMETER" (cdr (assoc 0 (entget (cdr pair)))))
(cdr pair)
(dictsearch
(vlax-vla-object->ename (vla-getextensiondictionary blk))
"ACAD_ENHANCEDBLOCK"
(cdr (assoc 301 (entget vis)))
Marcelo
Replies (17)
Message 2 of 18
hmsilva
Hi Marcelo,
just for debugging, if you select a viewport with
(rtos (/ 1 (vla-get-CustomScale (vlax-ename->vla-object (car (entsel))))) 2 0)
what's the return?
Henrique
Message 3 of 18
msarqui
Hi Henrique,
It returns...
"1" for scale 1:1
"2" for scale 1:2
"3" for scale 1:2.5
"8" for scale 1:7.5
"100" for scale 1:100
Message 4 of 18
hmsilva
Did you test it?
Is it possible to attach a sample dwg with a few layouts and viewports?
Henrique
Message 5 of 18
msarqui
Here it goes...
Let me know if you need something more 🙂
Message 6 of 18
hmsilva
Marcelo, try this quickly revised code
    (foreach layout (layoutlist) ;(setq layout "G02")
                 (setq ss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 layout) (cons -4 "!=") (cons 69 1))))
            ) ; and
            (cond
            ) ;cond
            (MS:ChangeVisibility "AUCUNE") ;Without viewport
        ) ; if
    ) ;foreach
    (princ)
 ;https://forums.autodesk.com/t5/visual-lisp-autoli?sp-and-general/changing-visibility-states-in-dynam?ic-block/td-p/5322263
(defun MS:ChangeVisibility (vis / blk idx obj sel)
    (princ)
(defun LM:blockname (obj)
        (defun LM:blockname (obj) (vla-get-effectivename obj))
        (defun LM:blockname (obj) (vla-get-name obj))
    (LM:blockname obj)
(defun LM:SetVisibilityState (blk val / vis)
    (if
        (and
(defun LM:setdynpropvalue (blk prp val)
    (vl-some
        '(lambda (x)
                 (progn
                     (cond (val)
                           (t)
(defun LM:getdynpropallowedvalues (blk prp)
    (vl-some '(lambda (x)
(defun LM:getvisibilityparametername (blk / vis)
    (if
        (and
            (setq blk
                     (vla-item
            (setq vis
                     (vl-some
                         '(lambda (pair)
                              (if
                                  (and
                                      (= 360 (car pair))
                                     (cdr pair)
                         (dictsearch
Hope this helps,
Henrique
Message 7 of 18
msarqui
Henrique,
Tested in my sample and:
Page G03 not working. In case of multiple viewports with different scales we need to put the scale block to "INDIQUÉE" (it means AS SHOWN in english, because I will add later a specific scale bar for each viewport). So, in this case, (setq ss1 "INDIQUÉE").
Page G05 not working. If the scale of the viewport is not on the routine's list, put the scale block to "AUCUNE" (It means NONE in english). So in this case,(setq ss1 "AUCUNE")
Also, scales 1:1, 1:2, 1:2.5, 1:3... (lower than 1:10) are not working. Attached a new sample with viewports in those scales.
Thanks!!!
Message 8 of 18
hmsilva
@msarqui wrote:
Henrique,
Thanks!!!
Marcelo,
in your original code, you don't have 'tests' for those situations... later, I'll see what I can do.
Henrique
Message 9 of 18
ВeekeeCZ
@msarqui wrote:
Also, scales 1:1, 1:2, 1:2.5, 1:3...... are not working. Attached a new sample with viewports in those scales.
Look inside your block, there is no such VISIBILITY STATES defined.
And some other notes:
Spoiler
;Make sure that DIMZIN variable have correct value... if you're using rtos and the the result for later comparation
; I would prefer keep numpers as far as possible:
(setq ss1 (/ 1 (vla-get-CustomScale (vlax-ename->vla-object (ssname ss 0)))))
; Then these two lines...
(if (member ssi '(1 2 2.5 3 5 7.5 10 15 20 25 30 40 50 75 100 125 150 200 250 300 350 400 500 600 750 1000 2000 2500))
  (MS:ChangeVisibility (strcat "1:" (rtos ss1 2 0))))
; ... can replace whole these....
(cond
            ) ;cond
Message 10 of 18
msarqui
Well... I am reeeealy embarrassed     Smiley Embarassed
I started this post at home and continued at work, so I took the wrong block here.
Attached the new file with the right block.
But still... In the Henrique's code, if the viewport scale is 1:2.5, the block change to 1:3
I will give a try on yours BeekeeCZ
Thanks!
Message 11 of 18
ВeekeeCZ
If you descibe your problem like this, then is the reason obvious. (and I copycat the same)
  (MS:ChangeVisibility (strcat "1:" (rtos ss1 2 1))))
Message 12 of 18
msarqui
This change will bug the scales higher than 1:10
I think we need to find the middle term between one and two digits.
Message 13 of 18
hmsilva
Marcelo,
perhaps something like this
(defun c:VS (/ i lst pos retab sc ss vis)
            ) ; and
            (progn
                (setq lst nil)
                (repeat (setq i (sslength ss))
                    (setq sc  (/ 1 (vla-get-CustomScale (vlax-ename->vla-object (ssname ss (setq i (1- i))))))
                          lst (cons sc lst)
                (cond ((and (vl-every (function (lambda (x) (equal x sc))) lst)
                            (setq pos (vl-position
                                          sc
                                          '(1.0     2.0     2.5     3.0     5.0     7.5     10.0    15.0    20.0    25.0    30.0    40.0    50.0    75.0
                                            100.0   125.0   150.0   200.0   250.0   300.0   350.0   400.0   500.0   600.0   750.0   1000.0  2000.0  2500.0
                            (setq vis (nth pos
                                           '("1:1"      "1:2"      "1:2.5"    "1:3"      "1:5"      "1:7.5"    "1:10"     "1:15"     "1:20"     "1:25"
                                             "1:30"     "1:40"     "1:50"     "1:75"     "1:100"    "1:125"    "1:150"    "1:200"    "1:250"    "1:300"
                                             "1:350"    "1:400"    "1:500"    "1:600"    "1:750"    "1:1000"   "1:2000"   "1:2500"
                      (T
                       (MS:ChangeVisibility "INDIQUÉE")
        ) ; if
    ) ;foreach
    (princ)
    (princ)
    (LM:blockname obj)
    (if
        (and
    (vl-some
        '(lambda (x)
                 (progn
                     (cond (val)
                           (t)
    (if
        (and
            (setq blk
                     (vla-item
            (setq vis
                     (vl-some
                         '(lambda (pair)
                              (if
                                  (and
                                      (= 360 (car pair))
                                     (cdr pair)
                         (dictsearch
Hope this helps,
Henrique
Message 14 of 18
msarqui
@msarqui wrote:
Henrique,
Page G03 not working. In case of multiple viewports with different scales we need to put the scale block to "INDIQUÉE" (it means AS SHOWN in english, because I will add later a specific scale bar for each viewport). So, in this case, (setq ss1 "INDIQUÉE"). Perfect, now it is working here.
Page G05 not working. If the scale of the viewport is not on the routine's list, put the scale block to "AUCUNE" (It means NONE in english). So in this case,(setq ss1 "AUCUNE") It is still not workin here. Instead of AUCUNE it gave me INDIQUÉE. In this scenario, it must be AUCUNE, because the viewport do not has a valid scale. So, I can not use the scale bar to mesure the printed sheet.
Also, scales 1:1, 1:2, 1:2.5, 1:3... (lower than 1:10) are not working. Attached a new sample with viewports in those scales. Perfect, now it is working here.
Almost there Henrique!
Message 15 of 18
hmsilva
Revised
            ) ; and
            (progn
                (setq lst nil)
                          lst (cons sc lst)
                (if (vl-every (function (lambda (x) (equal x sc))) lst)
                    (if (and
                                          sc
                            (setq vis (nth pos
        ) ; if
    ) ;foreach
    (princ)
    (princ)
    (LM:blockname obj)
    (if
        (and
    (vl-some
        '(lambda (x)
                 (progn
                     (cond (val)
                           (t)
    (if
        (and
            (setq blk
                     (vla-item
            (setq vis
                     (vl-some
                         '(lambda (pair)
                              (if
                                  (and
                                      (= 360 (car pair))
                                     (cdr pair)
                         (dictsearch
Hope this helps,
Henrique
Message 16 of 18
msarqui
Testing...
Message 17 of 18
msarqui
Working pretty nice.
Many many thanks Henrique. Smiley Very Happy
Message 18 of 18
hmsilva
You're welcome, Marcelo!
Glad I could help
Henrique
