Viewport Outline layer
Hamza.itani
Message 1 of 9
Hamza.itani
The following code creates polylines on a layer named "VPOutline". Each time one of the three commands - VPO, VPOL, or VPOA - is executed, I need the lisp to automatically configure the "VPOutline" layer to be non-plottable and change its color to cyan.
Can anyone please help?
;;-----------------------=={ Viewport Outline }==-----------------------;;
;;  This program allows the user to automatically generate a polyline   ;;
;;  in modelspace representing the outline of a selected paperspace     ;;
;;  viewport.                                                           ;;
;;  The command is only available in paperspace (that is, when a        ;;
;;  layout tab other than the Model tab is the current layout, and no   ;;
;;  viewports are active).                                              ;;
;;  Upon issuing the command syntax 'VPO' at the AutoCAD command-line,  ;;
;;  the user is prompted to select a viewport for which to construct    ;;
;;  the viewport outline in modelspace.                                 ;;
;;  Following a valid selection, the boundary of the selected viewport  ;;
;;  is transformed appropriately to account for the position, scale,    ;;
;;  rotation, & orientation of the modelspace view displayed through    ;;
;;  the selected viewport, and a 2D polyline (LWPolyline) representing  ;;
;;  this transformed boundary is constructed in modelspace.             ;;
;;  The program is compatible for use with all Rectangular, Polygonal & ;;
;;  Clipped Viewports (including those with Arc segments), and with all ;;
;;  views & construction planes.                                        ;;
;;  The program also offers the ability to optionally offset the        ;;
;;  polyline outline to the interior of the viewport boundary by a      ;;
;;  predetermined number of paperspace units specified in the           ;;
;;  'Program Parameters' section of the program source code.            ;;
;;  The program may also be configured to automatically apply a         ;;
;;  predefined set of properties (e.g. layer, colour, linetype, etc.)   ;;
;;  to the resulting polyline outline - these properties are also       ;;
;;  listed within the 'Program Parameters' section of the source code.  ;;
;;  Author:  Lee Mac, Copyright © 2015  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2015-01-02                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.1    -    2016-08-11                                      ;;
;;  - Program modified to account for polygonal viewports represented   ;;
;;    by 2D (Heavy) Polylines.                                          ;;
;;  Version 1.2    -    2017-09-03                                      ;;
;;  - Added the ability to specify an optional interior offset          ;;
;;    (relative to Paperspace Viewport dimensions).                     ;;
;;  - Added default polyline properties.                                ;;
;;  Version 1.3    -    2019-08-12                                      ;;
;;  - Restructured program as a main function accepting a viewport      ;;
;;    entity argument.                                                  ;;
;;  - Added two additional custom commands:                             ;;
;;    - 'vpol' - outlines all viewports in the active Paperspace layout ;;
;;    - 'vpoa' - outlines all viewports in all Paperspace layouts       ;;
;;  VPO - Outline a selected viewport in the active Paperspace layout   ;;
(defun c:vpo ( / *error* sel )
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
        (princ)
    (LM:startundo (LM:acdoc))
    (cond
        (   (/= 1 (getvar 'cvport))
            (princ "\nCommand not available in Modelspace.")
        (   (setq sel (LM:ssget "\nSelect viewport: " '("_+.:E:S" ((0 . "VIEWPORT")))))
            (vpo:main (ssname sel 0))
    (princ)
;;  VPOL - Outline all viewports in the active Paperspace layout        ;;
(defun c:vpol ( / *error* idx sel )
        (princ)
    (cond
        (   (setq sel (ssget "_X" (list '(0 . "VIEWPORT") '(-4 . "<>") '(69 . 1) (cons 410 (getvar 'ctab)))))
            (repeat (setq idx (sslength sel))
                (vpo:main (ssname sel (setq idx (1- idx))))
        (   (princ "\nNo viewports were found in the active layout."))
    (princ)
;;  VPOA - Outline all viewports in all Paperspace layouts              ;;
(defun c:vpoa ( / *error* idx sel )
        (princ)
    (cond
        (   (setq sel (ssget "_X" '((0 . "VIEWPORT") (-4 . "<>") (69 . 1) (410 . "~Model"))))
        (   (princ "\nNo viewports were found in any Paperspace layouts."))
    (princ)
(defun vpo:main ( vpt / cen dpr ent lst ltp ocs ofe off tmp vpe )
    (setq
;;                          Program Parameters                          ;;
        ;; Optional Interior Offset
        ;; Set this parameter to nil or 0.0 for no offset
        off 0.0
        ;; Default Polyline Properties
        ;; Omitted properties will use current settings when the program is run
        dpr
            (006 . "BYLAYER")   ;; Linetype (must be loaded)
            (008 . "VPOutline") ;; Layer (automatically created if not present in drawing)
            (039 . 0.0)         ;; Thickness
            (048 . 1.0)         ;; Linetype Scale
            (062 . 256)         ;; Colour (0 = ByBlock, 256 = ByLayer)
            (370 . -1)          ;; Lineweight (-1 = ByLayer, -2 = ByBlock, -3 = Default, 0.3 = 30 etc.)
    (if (setq vpt (entget vpt)
              ent (cdr (assoc 340 vpt))
        (setq lst (vpo:polyvertices ent))
        (setq cen (mapcar 'list (cdr (assoc 10 vpt))
                      (list
                          (/ (cdr (assoc 40 vpt)) 2.0)
                          (/ (cdr (assoc 41 vpt)) 2.0)
              lst (mapcar '(lambda ( a ) (cons (mapcar 'apply a cen) '(42 . 0.0))) '((- -) (+ -) (+ +) (- +)))
    (if (not (LM:listclockwise-p (mapcar 'car lst)))
        (setq lst (reverse (mapcar '(lambda ( a b ) (cons (car a) (cons 42 (- (cddr b))))) lst (cons (last lst) lst))))
    (if (and (numberp off) (not (equal 0.0 off 1e-8)))
        (cond
            (   (null
                    (setq tmp
                        (entmakex
                            (append
                                (list
                                   '(000 . "LWPOLYLINE")
                                   '(100 . "AcDbEntity")
                                   '(100 . "AcDbPolyline")
                                    (cons 90 (length lst))
                                   '(070 . 1)
                                (apply 'append (mapcar '(lambda ( x ) (list (cons 10 (car x)) (cdr x))) lst))
                (princ "\nUnable to generate Paperspace outline for offset.")
            (   (vl-catch-all-error-p (setq ofe (vl-catch-all-apply 'vlax-invoke (list (vlax-ename->vla-object tmp) 'offset off))))
                (princ (strcat "\nViewport dimensions too small to offset outline by " (rtos off) " units."))
                (entdel tmp)
            (   (setq ofe (vlax-vla-object->ename (car ofe))
                      lst (vpo:polyvertices ofe)
                (entdel ofe)
                (entdel tmp)
    (setq vpe (cdr (assoc -1 vpt))
          ocs (cdr (assoc 16 vpt))
    (entmakex
        (append
            (list
               '(070 . 1)
               '(410 . "Model")
            (if (and (setq ltp (assoc 6 dpr)) (not (tblsearch "ltype" (cdr ltp))))
                (progn
                    (princ  (strcat "\n\"" (cdr ltp) "\" linetype not loaded - linetype set to \"ByLayer\"."))
                    (subst '(6 . "BYLAYER") ltp dpr)
                dpr
            (apply 'append (mapcar '(lambda ( x ) (list (cons 10 (trans (pcs2wcs (car x) vpe) 0 ocs)) (cdr x))) lst))
            (list (cons 210 ocs))
(defun vpo:polyvertices ( ent )
    (apply '(lambda ( foo bar ) (foo bar))
        (if (= "LWPOLYLINE" (cdr (assoc 0 (entget ent))))
            (list
                (lambda ( enx )
                    (if (setq enx (member (assoc 10 enx) enx))
                        (cons (cons  (cdr (assoc 10 enx)) (assoc 42 enx)) (foo (cdr enx)))
                (entget ent)
            (list
                (lambda ( ent / enx )
                    (if (= "VERTEX" (cdr (assoc 0 (setq enx (entget ent)))))
                        (cons (cons (cdr (assoc 10 enx)) (assoc 42 enx)) (foo (entnext ent)))
                (entnext ent)
;; List Clockwise-p  -  Lee Mac
;; Returns T if the point list is clockwise oriented
(defun LM:listclockwise-p ( lst )
    (minusp
        (apply '+
            (mapcar
                (function
                    (lambda ( a b )
                        (- (* (car b) (cadr a)) (* (car a) (cadr b)))
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
;; PCS2WCS (gile)
;; Translates a PCS point to WCS based on the supplied Viewport
;; (PCS2WCS pt vp) is the same as (trans (trans pt 3 2) 2 0) when vp is active
;; pnt : PCS point
;; ent : Viewport ename
(defun PCS2WCS ( pnt ent / ang enx mat nor scl )
    (setq pnt (trans pnt 0 0)
          enx (entget ent)
          ang (- (cdr (assoc 51 enx)))
          nor (cdr (assoc 16 enx))
          scl (/ (cdr (assoc 45 enx)) (cdr (assoc 41 enx)))
          mat (mxm
                  (mapcar (function (lambda ( v ) (trans v 0 nor t)))
                     '(   (1.0 0.0 0.0)
                          (0.0 1.0 0.0)
                          (0.0 0.0 1.0)
                  (list
                      (list (cos ang) (- (sin ang)) 0.0)
                      (list (sin ang)    (cos ang)  0.0)
                     '(0.0 0.0 1.0)
    (mapcar '+
        (mxv mat
            (mapcar '+
                (vxs pnt scl)
                (vxs (cdr (assoc 10 enx)) (- scl))
                (cdr (assoc 12 enx))
        (cdr (assoc 17 enx))
;; Matrix Transpose  -  Doug Wilson
;; Args: m - nxn matrix
(defun trp ( m )
    (apply 'mapcar (cons 'list m))
;; Matrix x Matrix  -  Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
    ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; Vector x Scalar  -  Lee Mac
;; Args: v - vector in R^n, s - real scalar
(defun vxs ( v s )
    (mapcar '(lambda ( n ) (* n s)) v)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(princ
    (strcat
        "\n:: VPOutline.lsp | Version 1.3 | \\U+00A9 Lee Mac "
        ((lambda ( y ) (if (= y (menucmd "m=$(edtime,0,yyyy)")) y (strcat y "-" (menucmd "m=$(edtime,0,yyyy)")))) "2015")
        " www.lee-mac.com ::"
        "\n:: \"vpo\"  - Outline single viewport                ::"
        "\n:: \"vpol\" - Outline all viewports in active layout ::"
        "\n:: \"vpoa\" - Outline all viewports in all layouts   ::"
(princ)
;;                             End of File                              ;;
Replies (8)
Message 2 of 9
ВeekeeCZ
Below each this line
add this line
(or (tblsearch "layer" "VPOutline") (entmake '((0 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "VPOutline") (62 . 4) (70 . 0) (290 . 0))))
Message 3 of 9
Hamza.itani
I added the new line in 3 places as advised.
Once loading the lisp, I'm getting this:
Error: bad argument type: consp 0
Modified code:
        (princ)
(or (tblsearch "layer" "VPOutline") (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(2 . "VPOutline") '(62 . 4) '(70 . 0) (290 . 0))))
    (cond
    (princ)
        (princ)
    (cond
    (princ)
        (princ)
    (cond
    (princ)
    (setq
        off 0.0
        dpr
                      (list
        (cond
            (   (null
                    (setq tmp
                        (entmakex
                            (append
                                (list
                                   '(070 . 1)
                (entdel tmp)
                (entdel ofe)
                (entdel tmp)
    (entmakex
        (append
            (list
               '(070 . 1)
               '(410 . "Model")
                (progn
                dpr
            (list
                (lambda ( enx )
                (entget ent)
            (list
                (entnext ent)
    (minusp
        (apply '+
            (mapcar
                (function
                    (lambda ( a b )
;; ssget  -  Lee Mac
    (princ msg)
    (setvar 'nomutt 1)
    (setvar 'nomutt 0)
;; PCS2WCS (gile)
;; pnt : PCS point
          enx (entget ent)
          mat (mxm
                     '(   (1.0 0.0 0.0)
                          (0.0 1.0 0.0)
                          (0.0 0.0 1.0)
                  (list
                     '(0.0 0.0 1.0)
    (mapcar '+
        (mxv mat
            (mapcar '+
                (vxs pnt scl)
(defun trp ( m )
(defun mxm ( m n )
(defun mxv ( m v )
(defun vxs ( v s )
    (LM:endundo doc)
(defun LM:acdoc nil
    (LM:acdoc)
(princ
    (strcat
(princ)
Message 4 of 9
Hamza.itani
Once I added the new line below each instance of (LM:startundo (LM:acdoc)) , I'm getting Error: bad argument type: consp 0
Message 5 of 9
ВeekeeCZ
Ok, updated.
Message 6 of 9
paullimapa
FYI since the code is copyrighted by the author you may want to contact him first.
Paul Li
IT Specialist
@The Office
Message 7 of 9
Hamza.itani
Thanks for the heads-up,
But I just checked his website, and according to his terms (https://www.lee-mac.com/terms.html) we are allowed to modify for personal and organizational use, as long as we don't modify the headers.
If not I'm sorry.
Message 8 of 9
paullimapa
http://www.lee-mac.com/terms.html
good that you pointed to this link.
Things to consider
1.
ANY MODIFICATION TO PUBLISHED CODE SHOULD BE INDICATED TO PROVIDE NOTIFICATION THAT AN ALTERATION HAS BEEN MADE TO THE ORIGINAL CODE.
2.
Finally, if you intend to make reference to the programs published on this site on forums or other sites, it is preferable that you provide a link to the program on this site rather than post the code in its entirety on an external site
Paul Li
IT Specialist
@The Office
Message 9 of 9
Hamza.itani
Will do.
