View top (without zoom)
BB8x
Message 1 of 8
BB8x
Hello
(defun C:VT () (command "_-VIEW" "Top"))
I use this to set top view (speeds me up). Is there a way to add something to this tiny lisp? For now view top zooms out extents when used. Is there a way to keep actual window zoom as it is before view top is commenced?
Thank you
Replies (7)
Message 2 of 8
roland.r71
There was a lisp by @Kent1Cooper, modified by@marko_ribar on cadtutor, to do just that, but it's "unavailable". (maybe they can upload it here, if you ask 'm nicely? 😉)
Message 3 of 8
marko_ribar
Thanks for recommandetion...
This is link at cadtutor : https://www.cadtutor.net/forum/topic/62901-zoom-from-view-to-view-without-zooming-out-to-extend/?tab...
Here is at theswamp (show stuff forum - you must be logged) : http://www.theswamp.org/index.php?topic=52930.msg577565#msg577565
And also you have @Kent1Cooper version here at this forum : https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/views-from-predefined-directions-wit...
But this last version is from 2009. and I suppose not modified by me...
HTH. M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 4 of 8
roland.r71
@marko_ribarThe cadtutor link is the one i found, but it says: unavailable.
If I click it, it says:
Sorry, there is a problem
This attachment is not available. It may have been removed or the person who shared it may not have permission to share it to this location.
Error code: 2C171/1
Message 5 of 8
Kent1Cooper
In my command set that @marko_ribar linked to, that would be the VOO command, for View, Orthogonal, from Overhead.  If you want its DVIEW-based approach plugged into just your from-the-top command definition, it would be like this:
(defun C:VT ()
  (command "_.dview" "" "_points" "none" (getvar 'viewctr) "_none" "@0,0,1" "")
Kent Cooper, AIA
Message 6 of 8
marko_ribar
Error code: 2C171/1
Sorry to hear that... I'll attach what I have in my library...
Message 7 of 8
Sea-Haven
Opened link to cadtutor and open lsp no problems. It may be a if not a member ?
Message 8 of 8
roland.r71
That's possible. But I would expect something like:
"Sorry, To download attachments you need to be loged-in.
Don't have an account yet? click here."
