Very Very important lisp
107199
Message 1 of 1
107199
hi,
this lisp is used to draw duct there is some problems:
1-when drawing duct ( using DD) then taking Takeoff ( using DT) then you will have problems as DT snip multi line while it must snip single so i think the solution is to explode it after drawing using DD
2-elbow radius when changing the width it use the old width.
3-DT takeoff is use chamfer style but the favorite is fillet using radius 10 cm.
thanks
(defun c:dd(/ actDoc ang1 ang2 ang3 ptLst enDist
fPt lEnt lObj lPln oldVars oldWd
plEnd plStart1 plStart2 prDir
segLst Start stDist stLst tAng
vlaPln cFlg *error*)
(vl-load-com)
(defun GetPlineVer(plObj)
(mapcar 'cdr
(vl-remove-if-not
'(lambda(x)(=(car x)10))
(entget plObj)))
); end of GetPLineVer
(defun asmi-PlineSegmentDataList(plObj / cLst outLst)
(setq cLst
(vl-remove-if-not
'(lambda(x)(member(car x) '(10 40 41 42)))
(entget plObj))
outLst '()
); end setq
(while cLst
(if(assoc 40 cLst)
(progn
(setq outLst
(append outLst
(list
(list
(cdr(assoc 10 cLst))
(cdr(assoc 40 cLst))
(cdr(assoc 41 cLst))
(cdr(assoc 42 cLst))
); end list
); end list
); end if
); end setq
(repeat 4
(setq cLst(cdr cLst))
); end repeat
); end progn
(setq outLst
(append outLst
(list
(list
); end list
); end list
); end append
cLst nil
); end setq
); end if
); end while
outLst
); end of asmi-GetPlineSegmentData
(defun asmi-LayersUnlock(/ restLst)
(setq restLst '())
(vlax-for lay
(vla-get-Layers
(vla-get-ActiveDocument
(vlax-get-acad-object)))
(setq restLst
(append restLst
(list
(list
lay
(vla-get-Lock lay)
(vla-get-Freeze lay)
); end list
); end list
); end append
); end setq
(vla-put-Lock lay :vlax-false)
(if
(vl-catch-all-error-p
(vl-catch-all-apply
'vla-put-Freeze(list lay :vlax-false)))
t)
); end vlax-for
restLst
); end of asmi-LayersUnlock
(defun asmi-LayersStateRestore(StateList)
(foreach lay StateList
(vla-put-Lock(car lay)(cadr lay))
(if
(vl-catch-all-apply
'vla-put-Freeze(list(car lay)(nth 2 lay))))
t)
); end foreach
(princ)
); end of asmi-LayersStateRestore
(defun PipeMLineStyle(/ dxfLst mlDict)
(setq dxfLst
(list'(0 . "MLINESTYLE")'(102 . "{ACAD_REACTORS")'(102 . "}")
'(100 . "AcDbMlineStyle") '(2 . "DUCT_PIPE")
'(70 . 274)'(3 . "")'(62 . 256)'(51 . 1.5708)'(52 . 1.5708)
'(71 . 2)'(49 . 0.5)'(62 . 256)'(6 . "BYBLOCK")
'(49 . -0.5)'(62 . 256)'(6 . "BYBLOCK"))); end setq
(if
(null
(member
(assoc 2 dxfLst)
(dictsearch
(namedobjdict)
"ACAD_MLINESTYLE")))
(progn
(setq mlDict
(cdr
(assoc -1
(dictsearch
(namedobjdict)
"ACAD_MLINESTYLE"))))
(dictadd mlDict
(cdr(assoc 2 dxfLst))(entmakex dxfLst))
); end progn
); end if
); end of PipeMLineStyle
(defun SideCalculate(Wdth Ang / Rad)
(setq Ang(- pi Ang))
; (setq Rad(* (if (= dpipeelb "Mitered") 0.5 dpiper/w) Wdth))
(setq Rad(+ (* 0.5 Wdth)(if (= dpipeelb "Mitered") 0.0 dpiperad)))
(+ (if (= dpipeelb "Mitered") dpipetan 0)
(sqrt(-(* 2(expt Rad 2))(* 2(expt Rad 2)(cos Ang))))
(sin(- pi Ang)))(sin(/(- pi(- pi Ang))2.0)
); end of SideCalculate
(defun BodyFunction()
(if
(not
(equal lObj(entlast)))
(progn
(setq lEnt(entlast)
stLst(asmi-LayersUnlock)
segLst(asmi-PlineSegmentDataList lEnt)
vlaPln(vlax-ename->vla-object lEnt)
); end setq
(setvar "OSMODE" 0)
(setvar "CMDECHO" 0)
(while (/= 1(length segLst))
(setq stDist
(vlax-curve-getDistAtPoint vlaPln
(caar segLst))
enDist
(caadr segLst))
); end setq
(if(< 2(length segLst))
(progn
(setq ang1
(+(/ pi 2)(angle(caar segLst)(caadr segLst)))
ang2
(+(/ pi 2)(angle(caadr segLst)(car(nth 2 segLst))))
); end setq
); end progn
); end if
(if
(or
(not Start)
prDir
);end or
(setq plStart1
(vlax-curve-getPointAtDist vlaPln
stDist)
Start T); end setq
(setq plStart1
(+ stDist(SideCalculate(cadar segLst)ang3)))); end setq
); end if
(if(and ang1 ang2)
(progn
(if(> ang1 ang2)
(setq ang3(- ang1 ang2))
(setq ang3(- ang2 ang1))
); end if
(setq ang3(- pi ang3)
tAng ang3)
(if(minusp ang3)(setq ang3(- ang3)))
); end progn
); end if
(if
(or
(equal ang1 ang2 0.000001)
(= 2(length segLst))
); end or
(setq plEnd
enDist)
prDir T); end setq
(setq plEnd
(- enDist(SideCalculate(cadar segLst)ang3)))
prDir nil); end setq
); end if
(if
(setq plStart2
(+ enDist(SideCalculate(cadar segLst)ang3)))); end setq
); end if
(if
(=(cadar segLst)(nth 2(car segLst)))
(setq ptLst
(mapcar
'(lambda(x)(trans x 0 1)); end lambda
(append
(if (not (/= "Segmented" dpipeelb "Mitered"))
(progn
(setq ang4 (apply '(lambda(x)(atan x (sqrt (abs (1- (* x x))))))
(list (sin (- ang1 (/ pi 2.0) (angle plEnd plStart2)))))
(setq SegNum (cond ((or (= dpipeelb "Mitered") (< (abs ang4)
(* (/ 35 360.0) pi))) 2) ((< (abs ang4) (* (/ 55 360.0) pi)) 3)
((< (abs ang4) (* (/ 75 360.0) pi)) 4) (T 5))
(setq tan4 (+ (if (= dpipeelb "Mitered") dpipetan 0.0) (*
; (if (= dpipeelb "Mitered") 0.5 dpiper/w) (cadar segLst)
(+ (* 0.5 (cadar segLst))(if (= dpipeelb "Mitered") 0.0 dpiperad))
(abs (apply '(lambda(x) (/ (sin x) (cos x))) (list (/ ang4
0.5 (1- SegNum) 2.0))))))
(setq mllst (list plEnd (polar plEnd (- ang1 (/ pi 2.0)) tan4)))
(setq SegCnt 0)
(while (< (+ SegCnt 2) SegNum)
(setq mllst (append mllst (list (polar (last mllst)
(+ (angle (cadr (reverse mllst)) (last mllst))
(/ ang4 -0.5 (1- SegNum))) (* tan4 2.0)))
SegCnt (1+ SegCnt)
(setq mllst (append mllst (list PlStart2)))
(setq SegCnt (- (length mllst) 2))
(setq pllst nil)
(while (> SegCnt 0)
(setq pllst (append pllst (list (polar (nth SegCnt mllst)
(+ (angle (nth (1- SegCnt) mllst) (nth SegCnt mllst))
(/ pi 2.0) (/ ang4 0.5 (1- SegNum) -2.0))
(/(cadar segLst)2(cos (/ ang4 0.5 (1- SegNum) 2.0)))))
SegCnt (1- SegCnt)
pllst
(list(polar plEnd ang1 (/(cadar segLst)2)))
(list(polar plEnd (+ pi ang1)(/(cadar segLst)2)))
(progn
(setq SegCnt 1)
(setq pllst nil)
(while (< SegCnt (1- (length mllst)))
(* pi 1.5) (/ ang4 0.5 (1- SegNum) -2.0))
SegCnt (1+ SegCnt)
(setq mllst (mapcar '(lambda(x)(trans x 0 1)) mllst))
pllst
(list(polar plStart2 (+ pi ang2)(/(cadar segLst)2)))
(list(polar plStart2 ang2 (/(cadar segLst)2)))
); end append
); end mapcar
); end setq
(setq ptLst
(mapcar
(list (polar plStart1 ang1 (/(cadar segLst)2))
(polar plStart1 (+ pi ang1)(/(cadar segLst)2))
(polar(caadr segLst)(+ pi ang2)(/(nth 2(car segLst))2))
(polar(caadr segLst)ang2(/(nth 2(car segLst))2))
); end list
); end mapcar
); end setq
); end if
); end if
(setq plStart1(trans plStart1 0 1)
plEnd(trans plEnd 0 1)
); end setq
(if plStart2
(setq plStart2(trans plStart1 0 1))
); end if
(if (< 2(length segLst))
(if (or (/=(cadar segLst)(nth 2(car segLst)))
(and (/= "Segmented" dpipeelb) (not(equal ang1 ang2 0.000001))
); end and
); end or
(progn
(setvar "PLINEWID" 0.0)
(command "_.pline")
(mapcar 'command ptLst)(command "_c")
(setvar "PLINEWID" dpipepWd)
); end progn
(if (and (= "Segmented" dpipeelb) (not(equal ang1 ang2 0.000001)))
(progn
(command "_.mline" "_st" "DUCT_PIPE" "_S" (cadar segLst) "_J" "_Z")
(mapcar 'command mlLst)
(command "")
; (setvar "PLINEWID" 0.0)
; (command "_.pline")
; (mapcar 'command ptLst)(command "_c")
; (setq SegCnt 0)
; (while (< SegCnt (1- SegNum))
; (command "_.line" (nth SegCnt ptlst)
; (nth (- (length ptlst) 3 SegCnt) ptlst)
; (setq SegCnt (1+ SegCnt))
; (setvar "PLINEWID" dpipepWd)
); end progn
); end if
); end if
); end if
(if
(and (= dpipeelb "Radius")
); end and
(progn
(setq lPln
(vlax-ename->vla-object(entlast))
tAng (abs (- ang2 ang1))
); end setq
(if (> tAng pi)
(if(< ang1 ang2)
(setq ang1(+ ang1 pi)
ang2(- ang2 pi)); end setq
(setq ang1(- ang1 pi)
ang2(+ ang2 pi)); end setq
); end if
); end if
(setq Bulge(/(sin(/(rem(- ang2 ang1)pi)4.0))(cos(/(rem(- ang2 ang1)pi)4.0))))
(vla-SetBulge lPln 1 Bulge)
(vla-SetBulge lPln 3 (- Bulge))
); end progn
); end if
(if
plStart1 plEnd "")
; (progn
; (setq ptLst
; (list (polar plStart1 (+ (angle plStart1 plEnd) (/ pi 2.0)) (/(cadar segLst)2))
; (polar plStart1 (- (angle plStart1 plEnd) (/ pi 2.0)) (/(cadar segLst)2))
; (polar plEnd (- (angle plStart1 plEnd) (/ pi 2.0)) (/(nth 2(car segLst))2))
; (polar plEnd (+ (angle plStart1 plEnd) (/ pi 2.0)) (/(nth 2(car segLst))2))
; ); end progn
); end if
(setq segLst(cdr segLst)); end setq
); end while
(command "_.erase" lEnt "")
(asmi-LayersStateRestore stLst)
); end progn
); end if
); end of Body Function
(defun *error*(msg)
(if actDoc
(vla-EndUndoMark actDoc)
); end if
(command "_.undo" "1")
(if oldVars
(mapcar 'setvar
'("FILLMODE" "PLINEWID" "CMDECHO" "OSMODE")
oldVars); end mapcar
); end if
(if (not (member msg '("console break" "Function cancelled" "quit / exit abort" "")))
(princ (strcat "\nError: " msg))
(princ)
); end of *error*
(PipeMLineStyle)
(if(not dpipepWd)(setq dpipepWd 1.0))
(setq oldWd dpipepWd
oldVars(mapcar 'getvar '("FILLMODE" "PLINEWID" "CMDECHO" "OSMODE"))
); end setq
(if(entlast)(setq lObj(entlast)))
(vla-StartUndoMark
(setq actDoc
(vlax-get-acad-object))))
(setq dlastelb dpipeelb)
(setq dlastelb "Radius")
(if (or (= dpipeelb "Mitered") (and (not dpipeelb) (= dlastelb "Mitered")))
(progn
(initget 6)
(setq dlasttan dpipetan
dpipetan (getdist (strcat "\nSpecify elbow throat length <"
(rtos (if (/= (type dlasttan) 'REAL)
(setq dlasttan (if (= (getvar "MEASUREMENT") 0) 6.0 100.0)) dlasttan)) ">: ")
(if (not dpipetan) (setq dpipetan dlasttan))
(if (not dpipeelb) (setq dpipeelb dlastelb))
(setq dlasttan nil)
(progn
(initget 6)
(setq dlastrad dpiperad
dpiperad 75
(if (not dpiperad) (setq dpiperad dlastrad))
; (setq dlastr/w dpiper/w
; dpiper/w (getdist (strcat "\nSpecify centerline r/w factor <"
; (rtos (if (/= (type dlastr/w) 'REAL)
; (setq dlastr/w 1.5) dlastr/w)) ">: ")
; (setq dlastr/w nil dpiper/w (max dpiper/w 0.5))
(initget 128)
(while(not cFlg)
(setq fPt
(getpoint
(strcat
"\nSpecify start point or width <"
(rtos dpipepWd) ">: " ))); end setq
(cond
((= 'LIST(type fPt))
(setq cFlg T)
); end condition #1
((= 'REAL(type(distof fPt)))
(setq dpipepWd(distof fPt)); end setq
); end condition #2
(T
(princ "\nInvalid option keyword! ")
); end condition #3
); end cond
); end while
(mapcar 'setvar
'("FILLMODE" "PLINEWID" "CMDECHO")
(list 0 dpipepWd 0)); end mapcar
(command "_.pline" fPt)
; (setq DLP (list DSP) PLN nil)
; (while (= (getvar "CMDNAMES") "PLINE")
; (princ (strcat "\nSpecify next point" (if (>= (length PLN) 3) " or [Undo/Width]" "") ": "))
; (setvar "CMDECHO" 0)
; (command PAUSE)
; (cond
; ((/= (getvar "CMDNAMES") "PLINE"))
; ((and (setq DLP (udelcon (append DLP (list (getvar "LASTPOINT"))))) (>= (length DLP) 2))
; (if (equal (angle (cadr (reverse DLP)) (last DLP)) (getvar "SNAPANG") 1E-12)
; (if (= (length DLP) 2)
; (command "" "_.pline" "_non" DSP "_non" (cadr DLP))
; (progn
; (if (= (caadr (reverse PLN)) 0.0)
; (command "_undo")
; (command "_line" "_non" (cadr DLP))
; (command "")
; (if (not (equal ERRENT (lent)))
; (progn
; (setq PT# 0 PLN (append (list (mapcar '(lambda (PNT DIR) (trans (mapcar '+ PNT DIR) (caar PLN) 1)) (list (cdadr PLN) (cdr (last PLN))) (cdar PLN)))
; (mapcar '(lambda (PNT) (append (list (car PNT)) (trans (cdr PNT) (caar PLN) 1))) (cdr (setq PLN (useldat (entlast))))))
; (foreach PNT (cdr PLN)
; (if (= (getvar "CMDNAMES") "")
; (command "_.ERASE" "_LAST" "" "_.PLINE" "_non" (cdr PNT))
; (command "_non" (cdr PNT))
; (if (/= (/= (car PNT) 0) (and (> PT# 0) (/= (car (nth (1- PT#) (cdr PLN))) 0)))
; (command (if (/= (car PNT) 0) "_a" "_l"))
; (setq PT# (1+ PT#))
; (if (and (/= (car PNT) 0) (or (/= (car PNT) 180) (nth PT# (cdr PLN))))
; (command "_a" (car PNT))
; (if (and (not (nth PT# (cdr PLN))) (/= (car PNT) 0) (/= (car PNT) 180))
; (command "_non" (cdar (cdr PLN)))
; (command (if DXP "" "_a"))
; (setvar "SNAPANG" (/ (* (apply '+ (mapcar 'car (cdr PLN))) PI) 180.0))
; (setq DLP (mapcar 'cdr (cdr PLN)))
; (progn
; (setq PLN nil DLP (list DSP))
; (setvar "SNAPANG" 0.0)
; (command "_.pline" "_non" DSP "_arc" "_direction" '(1.0 0.0))
(setvar "CMDECHO" 1)
(while(= 1(getvar "CMDACTIVE"))
(command pause)
); end while
(setq dpipepwd (getvar "PLINEWID"))
(BodyFunction)
(mapcar 'setvar
oldVars); end apply
(princ)
); end of c:wpipe
;;By Andrea Andreetti 2008-11-24 ;;
;; D U C T C O N N E C T ;;
(defun c:DT (/ dr_sel1 dr_sel1data p1 SDrain_10 SDrain_11 DuctStyle1)
;; Degre Conversion ;;
(defun dtr (a)
(* pi (/ a 180.0))
(defun rtd (a)
(/ (* a 180) pi)
;; Language Detection ;;
(if (vl-string-search "(FR)" (strcase (ver)))
(progn
(setq qstion0 "\nCommande: DuctConnect -Activé")
(setq qstion1 "Type de Conduit (C)arré/(R)ond <")
(setq qstion2 "Largeur du conduit: ")
(setq qstion3 "Sélection de la ligne du conduit: ")
(progn
(setq qstion0 "\nCommand: DuctConnect -Activated")
(setq qstion1 "Duct Type (S)quare/(R)ound <")
(setq qstion2 "Duct Width: ")
(setq qstion3 "Select Duct Line: ")
;; DuctStyle Detection ;;
(if (not DuctStyle) (Setq DuctStyle "C"))
(initget "S R C")
(setq DuctStyle1 (getkword (strcat qstion1 DuctStyle ">: ")))
(if DuctStyle1 (Setq DuctStyle DuctStyle1))
;; Selection and Data operation ;;
(setq LarDC (getreal qstion2))
(setq LarDC2 (/ LarDC 2))
(setq dr_sel1 nil)
(while (or (= dr_sel1 nil)
(/= (cdr (assoc 0 (setq dr_sel1data (entget (car dr_sel1))))) "LINE"))
(progn
(princ qstion3)
(setq dr_sel1 (entsel))
(setq p1 (osnap (cadr dr_sel1) "_near"))
(setq SDrain_10 (cdr (assoc 10 dr_sel1data))) ;Start Point
(setq SDrain_11 (cdr (assoc 11 dr_sel1data))) ;End Point
(setq SDrain_8 (cdr (assoc 8 dr_sel1data))) ;Layer
(setq SDrain_62 (cdr (assoc 62 dr_sel1data))) ;Color
(setq SDrain_6 (cdr (assoc 6 dr_sel1data))) ;Linetype
;; Units detection for ZY and ZY2 variables ;;
(if (< (getvar "LUNITS") 3)
(setq zy 100)
(setq zy 4)
(setq zy2 (/ zy 2))
;; PREVIEW MODE ;;
(simulductattach)
;; PREVIEW MODE ;;
;; S I M U L D U C T A T T A C H ;;
(defun simulductattach (/ #elp agp1 pstart1 pstart2 pointtomod ndrainent)
(while (= (car (setq grr (grread t 2))) 5)
(redraw)
(grdraw p1 (polar p1 (dtr 0) zy2) 52 1)
(grdraw p1 (polar p1 (dtr 45) zy2) 52 1)
(grdraw p1 (polar p1 (dtr 90) zy2) 52 1)
(grdraw p1 (polar p1 (dtr 135) zy2) 52 1)
(grdraw p1 (polar p1 (dtr 180) zy2) 52 1)
(grdraw p1 (polar p1 (dtr 225) zy2) 52 1)
(grdraw p1 (polar p1 (dtr 270) zy2) 52 1)
(grdraw p1 (polar p1 (dtr 315) zy2) 52 1)
(setq #elp (car (cdr grr)))
(setq agp1 (inters #elp
(polar #elp (+ (angle sdrain_11 sdrain_10) (dtr 90)) 2.0)
sdrain_10
sdrain_11
nil
(if (not agp1)
(polar #elp (+ (angle sdrain_10 sdrain_11) (dtr 90)) 2.0)
sdrain_10
sdrain_11
nil
(setq Djp1 (polar agp1 (angle agp1 p1) (+ LarDC2 zy)))
(setq Djpx (polar Djp1 (angle Djp1 agp1) zy))
(setq DjpA (polar Djpx (angle agp1 #elp) zy))
(setq DLp1 (polar Djpx (angle agp1 #elp) (distance agp1 #elp)))
(setq Djp2 (polar agp1 (angle p1 agp1) LarDC2))
(setq DLp2 (polar Djp2 (angle agp1 #elp) (distance agp1 #elp)))
(setq Djpb (polar Djp2 (angle agp1 #elp) zy))
(grdraw djp1 djpa 141 1)
(grdraw djpa dlp1 141 1)
(grdraw djpa djpb 141 1)
(grdraw djp2 dlp2 141 1)
(if (eq DuctStyle "R")
(progn
(setq djpm (polar djpa (angle djpa djpb) (/ (distance djpa djpb) 2)))
(setq djrja (polar djpa (angle agp1 #elp) (* zy 0.75)))
(setq djrjb (polar djpb (angle agp1 #elp) (* zy 0.75)))
(grdraw djp1 djpm 1 1)
(grdraw djp2 djpm 1 1)
(grdraw djrja djrjb 33 1)
(if (eq (car grr) 3)
(progn
(if (and djp1 djpa dlp1 djp2 dlp2 djpa djpb djrja djrjb)
(progn
(Duct_entmake djp1 djpa SDrain_6 SDrain_62 SDrain_8)
(Duct_entmake djpa dlp1 SDrain_6 SDrain_62 SDrain_8)
(Duct_entmake djp2 dlp2 SDrain_6 SDrain_62 SDrain_8)
(Duct_entmake djpa djpb SDrain_6 SDrain_62 SDrain_8)
(Duct_entmake djp1 djpm "continuous" 1 SDrain_8)
(Duct_entmake djp2 djpm "continuous" 1 SDrain_8)
;;Assume that ACAD.LIN exist and contain the ACAD_ISO03W100 Linetype.
(if (not (member "ACAD_ISO03W100" (mapcar 'strcase (ai_table "LTYPE" 0))))
(vl-cmdf "._linetype" "_L" "ACAD_ISO03W100" "acad.lin"))
(Duct_entmake djrja djrjb "ACAD_ISO03W100" 33 SDrain_8)
(redraw)
(if (and djp1 djpa dlp1 djp2 dlp2 djpa djpb)
(progn
(redraw)
(redraw)
(simulductattach)
(progn (redraw) (exit)(princ))
;; D U C T _ E N T M A K E ;;
(defun Duct_entmake (#10p #11p ForceLinetype ForceColor ForceLayer / ety_data)
(setq ety_data
(list
'(0 . "LINE") ; Object type
(cons 10 #10p) ; Start Point
(cons 11 #11p) ; End Point
(cons 8 SDrain_8) ; Layer
(if ForceLinetype
(setq ety_data (append ety_data (list (cons 6 ForceLinetype))))
(if ForceColor
(setq ety_data (append ety_data (list (cons 62 ForceColor))))
(if (and DuctColor (/= DuctColor 256))
(setq ety_data (append ety_data (list (cons 62 DuctColor))))
(entmake ety_data)
;; AUTO-LOAD ;;
(princ
qstion0)
;;By Andrea Andreetti 2008-11-27 ;;
;; D U C T A T T A C H ;;
(defun c:DuctAttach (/ Ent_10 Ent_11 Ent_62 Ent_0 Inter_L1 Inter_L2 entData Basepoint1 Basepoint2
Dduct grjp1 grjp2 ficp1 ficp2 ficpX #DCswitch Dway1 Dway2 Dway3 Dway4 ArcEnt
dr_sel1 dr_sel2 SLi_0 VLA_line1 VLA_line1_start VLA_line1_end ArcEntLIST
VLA_line2 VLA_line2_start VLA_line2_end 4po GEN_clayercolor Input entData arcX arcY
newLine 1_sp 1_sp 3_sp 4_sp)
(setq ArcEnt nil)
(defun dtr (a)
(* pi (/ a 180.0))
(defun rtd (a)
(/ (* a 180) pi)
(DCclean)
(if (not #DCswitch)(setq #DCswitch 0))
(setq dr_sel1 nil
dr_sel2 nil)
(setq dr_sel1 (entsel "\nSlection des lignes du conduit..."))
(while (or (= dr_sel2 nil)
(/= (cdr (assoc 0 (setq dr_sel2data (entget (car dr_sel2))))) "LINE")
(setq dr_sel2 (entsel "\nSlection des lignes du conduit..."))
(if (and dr_sel1 dr_sel2)
(progn
(setq SLi_0 (cdr (assoc 8 (entget (car dr_sel1)))))
(setq VLA_line1 (vlax-ename->vla-object (car dr_sel1)))
(setq VLA_line1_start (vlax-get VLA_line1 'startpoint))
(setq VLA_line1_end (vlax-get VLA_line1 'endpoint))
(setq VLA_line2 (vlax-ename->vla-object (car dr_sel2)))
(setq VLA_line2_start (vlax-get VLA_line2 'startpoint))
(setq VLA_line2_end (vlax-get VLA_line2 'endpoint))
(setq 4po 100)
(setq 4po 4)
(setq GEN_clayercolor (cdr (assoc 62 (entget (tblobjname "layer" (getvar "clayer"))))))
(defun *error* (msg)
(DCclean)
(if VLA_line0 (progn (vlax-release-object VLA_line0)(setq VLA_line0 nil)))
(if VLA_line1 (progn (vlax-release-object VLA_line1)(setq VLA_line1 nil)))
(if Nline (progn (vlax-release-object Nline)(setq Nline nil)))
(if Sline (progn (vlax-release-object Sline)(setq Sline nil)))
(princ msg)
(while (and (setq Input (grread T 4 4))
(or (= (car Input) 5)
(and
(= (car Input) 2)
(= (cadr Input) 9)
;;SWITCH MODE ;;
(if (and (= (car Input) 2)
(= (cadr Input) 9)
(progn
(if (> #DCswitch 5)
(setq #DCswitch 0)
(setq #DCswitch (1+ #DCswitch))
(progn
(if (eq #DCswitch 0) (princ "\n- Switched to Square/Square excentric connection -"))
(if (eq #DCswitch 1) (princ "\n- Switched to Square/Square Straight connection -"))
(if (eq #DCswitch 2) (princ "\n- Switched to Square/Square Concentric connection -"))
(if (eq #DCswitch 3) (princ "\n- Switched to Round/Square Concentric connection -"))
(if (eq #DCswitch 4) (princ "\n- Switched to Round/Round Concentric connection -"))
(if (eq #DCswitch 4) (princ "\n- Switched to Round/Round Straight connection -"))
(DCswitch)
;;SWITCH MODE ;;
(DCclean)
(if (eq (car Input) 3)
(Ductattach_exe)
;; D C S W I T C H ;;
(defun DCswitch (/ )
(if (and (setq EntName (car (nentselp (setq cursorLocation (cadr Input)))))
(not (eq Iname EntName))
(progn
(DCclean)
(setq entData (entget EntName))
(setq Ent_0 (cdr (assoc 0 entData)))
(if (setq Ent_62 (assoc 62 entData))
(setq Ent_62 (cdr Ent_62))
(setq Ent_62 GEN_clayercolor)
(setq Ent_10 (cdr (assoc 10 entData)))
(setq Ent_11 (cdr (assoc 11 entData)))
(if (eq Ent_0 "LINE")
(progn
(setq VLA_line0 (vlax-ename->vla-object (cdr (car entData))))
(setq Inter_L1 (vlax-invoke VLA_line0 'intersectwith VLA_line1 acExtendBoth))
(setq Inter_L2 (vlax-invoke VLA_line0 'intersectwith VLA_line2 acExtendBoth))
(if (and Inter_L1 Inter_L2)
(progn
(if (<
(distance Inter_L1 VLA_line1_start)
(distance Inter_L1 VLA_line1_end)
(setq Basepoint1 VLA_line1_end)
(setq Basepoint1 VLA_line1_start)
(if (<
(distance Inter_L2 VLA_line2_start)
(distance Inter_L2 VLA_line2_end)
(setq Basepoint2 VLA_line2_end)
(setq Basepoint2 VLA_line2_start)
(setq Dduct (+ (distance Basepoint1 Basepoint2) 4po))
(setq grjp1 (polar Inter_L1 (angle Inter_L1 Basepoint1) 4po))
(setq grjp2 (polar Inter_L2 (angle Inter_L2 Basepoint2) 4po))
(if (/= (distance grjp1 Inter_L2)(distance grjp2 Inter_L1))
(if (> (distance grjp1 Inter_L2)(distance grjp2 Inter_L1))
(progn
(setq ficp1 (polar grjp1 (+ (angle inter_L1 grjp1) (dtr 90)) 4po))
(setq ficp2 (polar grjp1 (- (angle inter_L1 grjp1) (dtr 90)) 4po))
(if (< (distance ficp1 grjp2)(distance ficp2 grjp2))
(setq ficpx ficp1)
(setq ficpx ficp2)
(setq grjp2 (inters grjp1 ficpx inter_L2 basepoint2 nil))
(progn
(setq ficp1 (polar grjp2 (+ (angle inter_L2 grjp2) (dtr 90)) 4po))
(setq ficp2 (polar grjp2 (- (angle inter_L2 grjp2) (dtr 90)) 4po))
(if (< (distance ficp1 grjp1)(distance ficp2 grjp1))
(setq ficpx ficp1)
(setq ficpx ficp2)
(setq grjp1 (inters grjp2 ficpx inter_L1 basepoint1 nil))
;;joint Line
(grdraw Basepoint1 grjp1 Ent_62 1)
(grdraw Basepoint2 grjp2 Ent_62 1)
(grdraw grjp1 grjp2 Ent_62 1)
;;Square/Square excentric connection ;;
(if (= #DCswitch 0)
(progn
(if (and (/= #DCswitchOLD #DCswitch)
ArcEnt)
(progn (entdel ArcEnt)(setq ArcEnt nil))
(if (<
(distance cursorLocation Inter_L1)
(distance cursorLocation Inter_L2)
(progn
(setq Dway1 grjp1)
(setq Dway2 (polar Inter_L1 (angle Inter_L2 Inter_L1) 4po))
(setq Dway3 grjp2
Dway4 Inter_L2)
(progn
(setq Dway1 grjp2)
(setq Dway2 (polar Inter_L2 (angle Inter_L1 Inter_L2) 4po))
(setq Dway3 grjp1
Dway4 Inter_L1)
(setq #DCswitchOLD #DCswitch)
;;Switched to Square/Square Straight connection ;;
(if (= #DCswitch 1)
(progn
ArcEnt)
(setq Dway1 grjp1
Dway2 Inter_L1
Dway3 grjp2
Dway4 Inter_L2
;;Switched to Square/Square Concentric connection ;;
(if (= #DCswitch 2)
(progn
ArcEnt)
(setq Dway1 grjp1
Dway2 (polar Inter_L1 (angle Inter_L2 Inter_L1) (/ 4po 2))
Dway3 grjp2
Dway4 (polar Inter_L2 (angle Inter_L1 Inter_L2) (/ 4po 2))
;;Switched to Round/Square Concentric connection ;;
(if (= #DCswitch 3)
(progn
ArcEnt)
(setq Dway1 grjp1
Dway3 grjp2
(setq Rj1 (polar Dway1 (angle Inter_L1 Basepoint1) (* 4po 0.75)))
(setq Rj2 (polar Dway3 (angle Inter_L2 Basepoint2) (* 4po 0.75)))
(grdraw Rj1 Rj2 33 1)
;;Switched to Round/Round Concentric connection ;;
(if (= #DCswitch 4)
(progn
ArcEnt)
(setq Dway1 grjp1
Dway3 grjp2
;;Draw ARC
(setq midjoint (polar Dway2 (angle Dway2 Dway4) (/ (distance Dway2 Dway4) 2)))
(setq cenOFarc (polar midjoint (+ (angle Dway2 Dway4) (dtr 90)) 4po))
(if (> (distance cenOFarc Dway1)(distance midjoint Dway1))
(setq cenOFarc (polar midjoint (- (angle Dway2 Dway4) (dtr 90)) 4po))
(setq arcX (polar midjoint (- (angle cenOFarc midjoint) (dtr 90)) (distance midjoint Dway2)))
(setq arcY (polar midjoint (+ (angle cenOFarc midjoint) (dtr 90)) (distance midjoint Dway2)))
(setq ArcEntLIST
(list
'(0 . "ARC");;Type
(cons 8 SLi_0);;Layer
'(100 . "AcDbCircle");;Catégorie
(cons 10 cenOFarc);;Center Point
(cons 40 (distance cenOFarc Dway2));;Radius
'(100 . "AcDbArc")
(cons 50 (angle cenOFarc arcX));;Dway2))
(cons 51 (angle cenOFarc arcY));;Dway4))
(cons 62 Ent_62)
(setq ArcEnt (entmakex ArcEntLIST))
;;Switched to Round/Round Straight connection ;;
(if (= #DCswitch 5)
(progn
ArcEnt)
(setq Dway1 grjp1
Dway2 Inter_L1
Dway3 grjp2
Dway4 Inter_L2
;;Draw ARC
(setq ArcEntLIST
(list
'(0 . "ARC");;Type
'(100 . "AcDbArc")
(cons 62 Ent_62)
;;GRDRAW Connection
(grdraw Dway1 Dway2 Ent_62 1)
(grdraw Dway3 Dway4 Ent_62 1)
(if (= (car Input) 11)(DCclean))
;; DUCTATTACH_EXE ;;
(defun Ductattach_exe ()
(if (and Dway1 Dway2 Dway3 Dway4)
(progn
(setq actdoc (vla-get-activedocument (vlax-get-acad-object)))
(setq space (if (= (getvar "cvport") 1)
(vla-get-paperspace actdoc)
(vla-get-modelspace actdoc)
(vla-put-StartPoint VLA_line1 (vlax-3d-point basepoint1))
(vla-put-EndPoint VLA_line1 (vlax-3d-point grjp1))
(vla-put-StartPoint VLA_line2 (vlax-3d-point basepoint2))
(vla-put-EndPoint VLA_line2 (vlax-3d-point grjp2))
(setq newLine (vlax-invoke space 'addline Dway1 Dway3))
(NLINE_chprop newline VLA_line1)
(setq newLine (vlax-invoke space 'addline Dway3 Dway4))
(setq newLine (vlax-invoke space 'addline Dway1 Dway2))
;; Round Duct Joint connection
(if (> #DCswitch 2)
(progn
(setq newLine (vlax-invoke space 'addline Rj1 Rj2))
;;Layer
(setq N_layer (vla-get-layer VLA_line1))
(vla-put-layer newLine N_layer)
;;Color
(vla-put-color newLine "33")
;;Linetype
(vl-cmdf "._linetype" "_L" "ACAD_ISO03W100" "acad.lin" ""))
(vla-put-linetype newline "ACAD_ISO03W100")
);_progn
);_if
;; Round Duct to Round Duct ARC design
(if (> #DCswitch 3)
(progn
(if ArcEntLIST (entmakex ArcEntLIST))
(setq newarc (vlax-ename->vla-object (entlast)))
(NLINE_chprop newarc VLA_line1)
(setq 1_sp (vlax-get VLA_line0 'startpoint))
(setq 4_sp (vlax-get VLA_line0 'endpoint))
(if (> (distance 1_sp Dway2)(distance 1_sp Dway4))
(progn
(setq 2_sp Dway4)
(setq 3_sp Dway2)
(progn
(setq 3_sp Dway4)
(setq 2_sp Dway2)
(vla-put-StartPoint VLA_line0 (vlax-3d-point 1_sp))
(vla-put-Endpoint VLA_line0 (vlax-3d-point 2_sp))
(setq newLine (vlax-invoke space 'addline 3_sp 4_sp))
(NLINE_chprop newline VLA_line0)
);_progn
;; NLINE_chprop ;;
(defun NLINE_chprop (Nline Sline)
;;Linetype
(setq N_linetype (vla-get-linetype Sline))
(vla-put-linetype NLine N_linetype)
;;Layer
(setq N_layer (vla-get-layer Sline))
(vla-put-layer NLine N_layer)
;;Color
(setq N_color (vla-get-Color Sline))
(vla-put-color NLine N_color)
;;Thickness
(setq N_thickness (vla-get-Thickness Sline))
(vla-put-Thickness NLine N_thickness)
;; NLINE_chprop ;;
;; DCclean ;;
(defun DCclean ()
(if ArcEnt (progn (entdel ArcEnt)(setq ArcEnt nil)))
(redraw)
;; DCclean ;;
Replies (0)
