Vertical Distance Quickly
ctpgamage
Message 1 of 12
ctpgamage
I want to review vertical Distance across horizontal lines quickly (not one by one).you can see attached image there are few layers horizontally i want to check the dimesion of vertical gap between that layers along vertical line very quickly not one by one.anyone have a lisp routine for that....?
Replies (11)
Message 2 of 12
ВeekeeCZ
How you want to check dimensions? Vertical dimensions? Or list to the command-line, eg. 0.46 - 0.35 - 0.15 - 0.15
Message 3 of 12
ctpgamage
dimension is better.if dificalt command line also ok...
Message 4 of 12
ВeekeeCZ
No difference.
(vl-load-com)
(defun c:DimVerticalInters ( / LM:intersections LM:intersectionsbetweensets ss ent pts)
  ;; Intersections  -  Lee Mac
  ;; Returns a list of all points of intersection between two objects
  ;; for the given intersection mode.
  ;; ob1,ob2 - [vla] VLA-Objects
  ;;     mod - [int] acextendoption enum of intersectwith method
  (defun LM:intersections ( ob1 ob2 mod / lst rtn )
    (if (and (vlax-method-applicable-p ob1 'intersectwith)
             (vlax-method-applicable-p ob2 'intersectwith)
             (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
      (repeat (/ (length lst) 3)
        (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
              lst (cdddr lst))))
    (reverse rtn))
  ;; Intersections Between Sets  -  Lee Mac
  ;; Returns a list of all points of intersection between objects in two selection sets.
  ;; ss1,ss2 - [sel] Selection sets
  (defun LM:intersectionsbetweensets ( ss1 ss2 / id1 id2 ob1 ob2 rtn )
    (repeat (setq id1 (sslength ss1))
      (setq ob1 (vlax-ename->vla-object (ssname ss1 (setq id1 (1- id1)))))
      (repeat (setq id2 (sslength ss2))
        (setq ob2 (vlax-ename->vla-object (ssname ss2 (setq id2 (1- id2))))
              rtn (cons (LM:intersections ob1 ob2 acextendnone) rtn))))
    (apply 'append (reverse rtn)))
  (if (and (princ "\nHorizontal lines: ")
           (setq ss (ssget ":S"))
           (setq ent (car (entsel "\nVertical line: ")))
           (setq pts (LM:intersectionsbetweensets ss (ssadd ent)))
           (setq pts (vl-sort pts '(lambda (y1 y2)
                                     (< (cadr y1) (cadr y2)))))
           (setq i 0)
    (repeat (1- (length pts))
      (command "_.DIMVERTICAL"
               "_none" (nth i pts)
               "_none" (nth (setq i (1+ i)) pts)
               "_none" "@")))
  (princ)
Message 5 of 12
ctpgamage
thanks beekeecs its works fine...can you make it dimensions?
Message 6 of 12
ВeekeeCZ
What do you mean by "make it dimensions". A layer?
Message 7 of 12
ctpgamage
yes..make a dimension is better....
Message 8 of 12
ВeekeeCZ
Ok, change the layer name if needed (blue)
(vl-load-com)
              lst (cdddr lst))))
    (reverse rtn))
           (setq i 0)
           (vl-cmdf "_.LAYER" "_T" "Dimensions" "_M" "Dimensions" "")
               "_none" (nth i pts)
               "_none" "@"
               "_.chprop" "_Last" "" "_Layer" "Dimensions" "")))
  (princ)
Message 9 of 12
ctpgamage
thanks brother ...
Message 10 of 12
ctpgamage
its working fine for new drawing.but not working for existing drawing. can you tell me why is that?
Message 11 of 12
ctpgamage
its ok i found the reason..its not working for named ucs only work for ucs world
Message 12 of 12
ВeekeeCZ
All we need to do is translate coordinates from WCS to UCS using the (trans) function.
Have fun!
(vl-load-com)
              lst (cdddr lst))))
    (reverse rtn))
           (setq i 0)
               "_none" (trans (nth i pts) 0 1)
               "_none" (trans (nth (setq i (1+ i)) pts) 0 1)
               "_none" "@"
  (princ)
