Verifying a minus sign
Henrik_Lo
Henrik_Lo
HI
I have a text, drawing name, within that are at value I need to calculate.
I need to calculate the value, but need to know if there is a minus. I need to know have many
places “substr” need, to get the value, if it is a minus, I need 4 digits if it is positive I only need 3 digits to get the value it out.
22-23910_PL_-0.1__AME_-0.7.dwg
22-23910_PL_0.1__AME_-0.7.dwg
(Setq NEL_PL (substr (getvar "dwgname") 13 1))                   ;Getting the value, I this case a minus sign
(setq NEL_PL_N (read NEL_PL))                                               ;change it to normal sign.
if I compare ( = NEL_PL_N -) I do not get T
If I do the same like this (= - -) I get T
WHY
Regards
Henrik
komondormrex
hey,
when comparing symbols they need to be quoted like in (= '- NEL_PL_N). minus function is quoted.
paullimapa
Curious as to why you don’t just continue to compare the character as a dash “-“ placed in a file name? Don’t need to use the read function but just do a character check like this
( = NEL_PL_N “-“)
Paul Li
IT Specialist
@The Office
Henrik_Lo
Hi thangs to you two, it´s seem to be working, jubiii.
Regards
Henrik
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
