VB.NET Upgrade ODtable error
Sgear
Sgear
Hi
I am try to Upgrade ODtable I get this error
Autodesk.Gis.Map.MapException: Exception of type 'Autodesk.Gis.Map.MapException' was thrown.
   Public Sub odTablesinsert(ByVal id, ByVal Category, ByVal Materials)
        Dim doc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim Ed As Editor = doc.Editor
        Dim trans As Transaction = db.TransactionManager.StartTransaction()
        Dim odTable As Autodesk.Gis.Map.ObjectData.Table
        Dim odTables As Autodesk.Gis.Map.ObjectData.Tables
        Dim mapVal As Autodesk.Gis.Map.Utilities.MapValue
        odTables = HostMapApplicationServices.Application.ActiveProject.ODTables
        odTable = odTables.Item("TABLE_NAME")
        Try
            Using docloc As DocumentLock = doc.LockDocument
                Dim dbObj As DBObject = trans.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
                Dim odrecords As ObjectData.Records = odTable.GetObjectTableRecords(Convert.ToUInt32(0), id, Constants.OpenMode.OpenForRead, False)
                Dim odRecord As ObjectData.Record = odrecords.Item(0)
                odRecord = Autodesk.Gis.Map.ObjectData.Record.Create()
                odTable.InitRecord(odRecord)
                If odrecords.Count = 0 Then
                    Ed.WriteMessage("New" & vbCr)
                    mapVal = odRecord(0)
                    mapVal.Assign(Category)
                    mapVal = odRecord(1)
                    mapVal.Assign(Materials)
                    odTable.AddRecord(odRecord, dbObj)
                Else
                    Ed.WriteMessage("Update" & vbCr)
                    odrecords.UpdateRecord(odRecord)  <<< ERROR
                odRecord.Dispose()
                odrecords.Dispose()
                trans.Commit()
            End Using
        Catch exc As Autodesk.Gis.Map.MapException
            MsgBox("Error : " + exc.Message.ToString())
        End Try
    End Sub
Sgear
Sorry Wrong please 🙂 just Ignore this or Delete I am finish to ask in .NET
http://forums.autodesk.com/t5/net/bd-p/152
