variables issue during combination of 2 subroutines (creating viewport)
This subroutine can create ONE rectangular viewport (as a part of other main routine)
(Defun VportRET (/ Ang Diag Pt1 Pt2 Pt2Lay Ptmed) (setvar "clayer" LayFIN) (setq Pt1 (getpoint "\nSpecify first window corner: ")) (setq Pt2 (getcorner pt1 "\nSpecify opposite corner: ")) (setq Ang (angle pt1 pt2)) (setq Diag (distance pt1 pt2)) (setq PtMed (polar Pt1 Ang (/ Diag 2))) (setvar "CTAB" Lay) (if (/= 1 (getvar "cvport"))(command "_.Pspace")) (if (/= SCA "Add") (progn (setq Pt2Lay (polar '(0 0) Ang (* Diag (atof FattZoom)))) (command "_.dragmode" "_auto") (setvar "osmode" 0) (command "_.-vports" "0,0" Pt2Lay) (setq Ent (entget (entlast))) (setq Entname (cdr (assoc -1 Ent))) (setq NumVP (cdr (assoc 69 Ent))) (command "_.zoom" "_w" "0,0" Pt2Lay) (command "_.mspace") (setvar "cvport" NumVP) (command "_.zoom" "_c" Ptmed ScXP) (command "_.pspace") (Command "zoom" "_all") (setvar "osmode" oldsnap) (princ "\nSpecify insertion point of viewport in Layout: ")(princ) (command "_.move" Entname "" "0,0" pause ) (command "_.mview" "_l" "_on" Entname "") ) ) (if (= SCA "Add") (progn (setq Wc1 (getpoint "\nSpecify first window corner: ")) (princ "\nSpecify opposite corner: ") (command "_.-vports" Wc1 pause) (setq Ent (entget (entlast))) (setq Entname (cdr (assoc -1 Ent))) (setq NumVP (cdr (assoc 69 Ent))) (command "_.mspace") (setvar "cvport" NumVP) (command "_.zoom" "_w" Pt1 Pt2) (command "_.pspace") (Command "zoom" "_all") (command "_.mview" "_l" "_on" Entname "") (setq WriteScala "0") ) ) )
I need to add option to create multiple viewports (more than one) depend of number given by user like it shown in a different subroutine (also a part of other main routine)
(setq lpno 2) ; Loop counter for making separate viewports (setq vpno (getint "\nNumber of separate viewports to make from this viewport <1>: ")) ; Will divide single viewport into separate viewports for othagonal views of 2D part (if (>= vpno 2) ; Proceed to copy current viewport if 2 or more separate viewports desired (progn (while (<= lpno vpno) ; Check if viewport loop counter less than number of viewports desired (command "copy" ssvp "" "0,0" "@0,0") ; Make copy of new viewport laying exactly on top of first viewport (setq lpno (1+ lpno)) ; Increment viewport loop counter (ssadd (entlast) ssvp1) ; Add viewport copy to selection set ) ) ) (setq ssnum 0) ; Loop counter for fine-tuning separate viewports (while (< ssnum (sslength ssvp1)) ; Opportunity to fine-tune each separate viewport border (setq vpent (ssname ssvp1 ssnum)) ; Get entity name of next viewport in selection set (if (>= vpno 2) ; Check for multiple viewports (setq clt (strcat " #" (rtos (+ ssnum 1) 2 0))) ; Make command prompt string if using multiple viewports (setq clt "") ; Make command prompt string if using single viewport ) (initget 128) ; Enable string responses from point prompt (setvar "osmode" 32) (setq nvpc1 (getpoint (strcat "\nSpecify first corner of viewport" clt " window area: "))) ; Pick actual part corner, program will apply offset (if nvpc1 ; Will repeat asking for first corner if none specified (progn (setq nvpc2 (getcorner nvpc1 (strcat "\nSpecify opposite corner of viewport" clt " window area: "))) ; Window rectangle can be designated in any direction, pick actual part corner, program will apply offset (if nvpc2 ; Will repeat asking for first corner if none specified (progn (setq nvpc1x (car nvpc1)) ; Find X portion of first corner (setq nvpc1y (cadr nvpc1)) ; Find Y portion of first corner (setq nvpc2x (car nvpc2)) ; Find X portion of second corner (setq nvpc2y (cadr nvpc2)) ; Find Y portion of second corner (if (> nvpc2x nvpc1x) ; Determine horizontal direction of viewport window rectangle (progn (setq nvpc2x (+ nvpc2x ofs)) ; Add horizontal offset to right of specified left-to-right window rectangle (setq nvpc1x (- nvpc1x ofs)) ; Add horizontal offset to left of specified left-to-right window rectangle ) (progn (setq nvpc2x (- nvpc2x ofs)) ; Add horizontal offset to left of specified right-to-left window rectangle (setq nvpc1x (+ nvpc1x ofs)) ; Add horizontal offset to right of specified right-to-left window rectangle ) ) (if (> nvpc2y nvpc1y) ; Determine vertical direction of viewport window rectangle (progn (setq nvpc2y (+ nvpc2y ofs)) ; Add vertical offset to top of specified lower-to-upper window rectangle (setq nvpc1y (- nvpc1y ofs)) ; Add vertical offset to bottom of specified lower-to-upper window rectangle ) (progn (setq nvpc2y (- nvpc2y ofs)) ; Add vertical offset to bottom of specified upper-to-lower window rectangle (setq nvpc1y (+ nvpc1y ofs)) ; Add vertical offset to top of specified upper-to-lower window rectangle ) ) (setvar "osmode" 0) ; Turn osnap off (command "rectang" (list nvpc1x nvpc1y) (list nvpc2x nvpc2y)) ; Make rectangle with offset to clip existing viewport (setvar "osmode" 2559) ; Turn osnap on (setq ssvp (ssget "L")) ; Select last rectange (command "vpclip" vpent ssvp) ; Clip existing viewport to rectangle (command "vpclip" ssvp "d" ) ; Convert Polygonal Vport to Rectangular (setq ssnum (1+ ssnum)) ; Increment fine-tuned viewport loop counter ) ) ) ) ) ) ) ) ) ) ) ) )
On this stage It's very complicated for me to do it because of different combinations of variables in these 2 subroutines
Can somebody help me to do it and add necessary addition to the first subroutine?
Any help will be very appreciated
