variable creation
variable creation
johnd
variable creation
johnd
Not sure if my first post went through:
I"m looking for suggestions for the following:
I have a series of rectangles that I want to create variable name and assign an elevation value to it
as it passes through a loop.
Start loop:
Select rectangle 1, assign an elevation then create variable Rectang-1-elev.
Select rectangle 2, assign an elevation then create variable Rectang-2-elev.
etc, etc,
Then later in the routine use a loop to with those variables to do a computation.
Start loop:
Rectang-1-elev - a value from variable
Rectang-2-elev - a value from variable.
etc, etc,
I don't want to keep typing
(setq Rectang-1-elev 2500)
(setq Rectang-2-elev 2800)
etc. etc.
Since I don't know how many rectangles would be present when the routine is ran.
Kent1Cooper
[Yes, the first one went through -- see my Reply there.]
Kent Cooper, AIA
john.uhden
@johnd ,
Might I recommend using handles and a list?...
something like...
(while (setq e (car (entsel)))
  (setq Z (getreal "Enter Z value: "))
  (setq mylist (cons (list (cdr (assoc 5 (entget e))) Z) mylist))
So that mylist looks something like '(("abc123" 22.3)("abc124" 25.7) etc.)
  (handle number)
Or ,if you prefer...
  (setq mylist (cons (cons (cdr (assoc 5 (entget e))) Z) mylist))
  (handle . number)
So that mylist looks something like '(("abc123" . 22.3)("abc124" . 25.7) etc.)
Then you can operate on the list whatever way you want.
Sorry, but I'm an old timer, so I often look at things decades past.
John F. Uhden
Sea-Haven
John this is posted twice.
john.uhden
@Sea-Haven ,
I hadn't noticed.  I have single vision.
John F. Uhden
