Valid Layers to choose from
rapidcad
Message 1 of 11
rapidcad
Hi all, I'm trying to add simple foolproof interface enhancements to a program that I have stitched together and I have a simple enough request. Does anyone know how I can take a list of layer names I'm making available to a pop_list and pare it down to display only the layers that are thawed, unlocked, on, and non x-ref layers? I'd like to present the users with only a list of valid layers to place my blocks on.
Up to this point, I'm just using this old Autolisp method to get a layer list...
(start_list "layer_pop_list")
(setq layer_list '()
      next_list (tblnext "Layer" T)
      index 0
(while next_list
  (if (= (getvar "clayer") (cdr (assoc 2 next_list)))
  (setq new_index index
	index (1+ index)
(setq layer_list (append layer_list (list (cdr (assoc 2 next_list))))
      next_list (tblnext "Layer")
;try to filter layer list here
;(setq good_layer_list layer_list)
(mapcar 'add_list layer_list)
(end_list)
(set_tile "layer_pop_list" (ITOA new_index))
Most programmers would probably know how to do this easily, but I'm getting rusty after spending so much time on building libraries.
ADN CAD Developer/Operator
Replies (10)
Message 2 of 11
scot-65
I'm not versed in VL as much as LISP, so here goes ("old" method)...
Xref has *|* as a WCMATCH pattern to the layer name.
DFX 70 has x = 0 for thaw and on (add 1 for frozen and add 4 for off).
DFX 62 has x < 0 for locked.
Let's try this in one swoop <untested>:
(while (setq a (tblnext "LAYER" (not a)))
(if (not (wcmatch (cdr (assoc 2 a)) "*|*"))
(if (= (cdr (assoc 70 a) 0))
(if (> (cdr (assoc 62 a) 0))
(setq b (list (cons (cdr (assoc 2 a)) b))) ;<--this might be wrong
);if
);if
);if
);while
(setq b (reverse b)) ;or ACAD_STRLSORT
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 3 of 11
john.uhden
This might work to create a list of layer names that meet your criteria (on, thawed, unlocked, not xref)
(defun layers_ok ( / layers okays)
  (setq layers (vlax-get (vla-get-activedocument (vlax-get-acad-object)) 'layers))
  (vlax-for layer layers
    (and
      (= (vlax-get layer 'layeron) -1)
      (= (vlax-get layer 'freeze) 0)
      (= (vlax-get layer 'lock) 0)
      (setq name (vlax-get layer 'name))
      (not (wcmatch name "*|*"))
      (setq okays (cons name okays))
  (reverse okays)
John F. Uhden
Message 4 of 11
rapidcad
Thanks Scott! I tried your code but ran into the errors (you thought there might be some though). By stepping through it I found that there were misplaced closing parenthesis in the assoc 70 and assoc 62 lines. However even after fixing them and getting the code to run, I still could not use the function because it returned a strange messed up list...
(("XREF" ("TGW-TAG" (...))))
instead of a nice list of layer names.
Here's my edited version that evaluates but returns this gibberish..
 (if (= (cdr (assoc 70 a)) 0)
 (if (> (cdr (assoc 62 a)) 0)
 );if
 );if
 );if
);while
Thank you so much for getting me reacquainted with parsing layer data. Haven't looked at it in a few years..
I'll keep plugging away at it.
Message 5 of 11
rapidcad
John, thanks a bunch for the excellent function. Although not simple Autolisp, the vlisp works flawlessly at what I'm doing and I mix the two quite a lot to get what I need done.  I think I'll try to incorporate this (with credits to you for the function). Works like a charm. Thanks again!
Smiley Happy
Message 6 of 11
john.uhden
I love getting good news.
Yes, mixing often yields tasteful (or tasty) results
John F. Uhden
Message 7 of 11
rapidcad
One small improvement if I am not missing some drawback to this method:
I like (acad_strlsort okays) instead of (reverse okays) because in my dialog box, I'm allowing users to create layers or add layers and they may be all caps or not. If I reverse the list, it puts any lowercase names at the bottom where you wouldn't think to look for them, while it looks like the acad_strlsort seems to integrate the lowers and uppers perfectly.
Let me know if there is some drawback to dong this.
Thanks again!
(defun layers_ok ( / layers okays name)
    (and
Message 8 of 11
john.uhden
Sure.  That will work just fine.  I noticed that you are wise enough to know there is no need for reversing.
Maybe it's just me, but I never liked lower case in layer names, or styles, or blocks.
If you are inclined the same way, then:
(mapcar 'strcase (acad_strlsort okays)), or
(acad_strlsort (mapcar 'strcase okays))
AutoCAD doesn't care about name case.
But I think the snvalid function can be your friend to avoid improper names.
John F. Uhden
Message 9 of 11
rapidcad
Thanks for those ideas. I think I'm going to have to allow the layer names to have different cases just because I'm writing a program for folks in our corporation and for use by distributors as well, so being strict about CAD standards hasn't been incorporated into the program the way I would do it otherwise. However, your tip about snvalid has me thinking how I might incorporate that since I had already considered that any string would be picked up by my dialog box and I knew that some characters are invalid for layer names.
What I asked about originally applied to a tile in the dialog to select a current layer from the list you helped me build, which I am not concerned about now that it works without a problem. However I have a separate tile which adds a new layer for the blocks being inserted which I am concerned about. I see there are easy ways to check through the list and test if a layer name is valid, but for the edit_box tile that just takes in whatever string it is fed, how can I test this and interact with the user if the string is invalid?
I tested this but I'm getting an endless while loop:
(defun is_legal_layername ()
  (while (not (snvalid create_layer_box))
	       	(set_tile "error" "Invalid layer name")
    		(setq create_layer_box (get_tile "create_layer_box")) )
(defun saveVars ()
  (setq layer_pop (nth (atoi (get_tile "layer_pop_list")) layer_list))
  (setq select_layer (get_tile "select_layer"))
  (setq current_layer (get_tile "current_layer"))
  (setq create_layer (get_tile "create_layer"))
  (if create_layer_box (is_legal_layername))
Of course, this isn't right, but without launching additional dialog boxes, how can I use errtile to inform the user of the mistake and prompt a correction?
This has been a good learning exercise for me and will certainly be so if this check can be implemented.
Thanks again for any help. I've already learned so much.
Message 10 of 11
john.uhden
(defun check_layer_box (value / done)
  (while (not done)
    (if (snvalid value)
      (progn
        (set_tile "error" "")
        (setq create_layer_box value
                 done 1
      (progn
        (mode_tile "create_layer_box" 2)  ; focus on tile
;; Notice that create_layer_box is global.
;; I would have named it newlayer.
;; Elsewhere:
(action_tile "create_layer_box" "(check_layer_box $value)")
John F. Uhden
Message 11 of 11
rapidcad
Thanks again John, I'll try to implement that. I really appreciate your help on this.
