Using Variables When Creating XDATA
mgorecki
mgorecki
I'm trying my hand at using XDATA.  I want to attach a variable text to a polyline.  The text value will change, it's not static.
I have seen examples where they use quoted strings for use in the entmod.
(setq exdata '((-3 ("PolyXdata" (1000 . "DETAILVIEW")))))
(setq newEnt (append selectedEnt exdata))
(entmod newEnt)
What I want to do is use a variable value in place of the quoted string.
(setq netNameXdata (cons 1000 xdataText))
(setq exdata '((-3 ("DocProXdata" netNameXdata))))
But that only gets me:
((-3 (CONS ("DocProXdata" NETNAMEXDATA))))
How can I use a variable value instead of a hard coded static string for this type of thing?
Mark
Ranjit_Singh
Maybe start with something like below function
(defun somefunc (x y)
(entmod (append y (list (list -3 (list (if (tblsearch "appid" x) x (regapp x)) '(1000 . "DETAILVIEW")))))))
 Above is just a basic structure to pass variable appid name. The rest of the data can be a variable as well. I am using the extended data as a variable in the below function but it could be passed as an argument to the main function as well. You get the idea.
(defun somefunc (x y / netnamexdata xdatatext)
(setq xdatatext "DETAILVIEW" netNameXdata (cons 1000 xdataText)) (entmod (append y (list (list -3 (list (if (tblsearch "appid" x) x (regapp x)) netnamexdata))))))
dgorsman
Expand on the XDATA you have as you would with LISP expressions, indenting with each consecutive open/close bracket.  Note the nested matching parenthesis after the single-quote/literal - it's constructing a list, "literally".  Use normal list-construction techniques with calls to (list ...) (cons ...) and so on to build the data in the same format.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
mgorecki
Hello Ranjit,
Thank you for that bit of code, it really helped me understand the sequence for the lists.
Best regards,
Mark
mgorecki
Hello dgorsman,
Thank you for your input.  I had tried a number of ways to write it before, but your post helped me stop, break it down, and take a look at where to use the lists.
This is what I have now and it works great.  Thank you both.
 ;Sets the variable exdata equal to the new extended data in this case, a text string.
 (setq exdata (list (list -3 (list "DocProXdata" netNameXdata))))
Best regards,
Mark
Ranjit_Singh
Don't forget that the piece of string (caadr (assoc -3 extendedentitydatalist)) needs to be a registered app. I will add the (tblsearch "appid" variablename) to your piece of code.
mgorecki
I had already registered "DocProXdata" as the app.
