Using "p2csv" lisp to exports selected AutoCAD points to a CSV file with user-defined options
mohamedhnfy
mohamedhnfy
Community Visitor
Community Visitor
This Lisp function, automates the export process of selected AutoCAD points to a user-specified CSV file. Here's a breakdown of its functionalities:
User Interaction:
  • Prompts the user to enter a desired filename for the exported data.
  • Offers a default filename ("points_output.csv") if no input is provided and automatically adds the ".csv" extension if missing.
  • Allows customization of text height for point labels within the drawing. Offers a default value (0.40) if no input is provided.
  • Enables configuration of a point name prefix (e.g., "P") and starting number for the sequence. Defaults to "P" for prefix and 1 for starting number if no input is given.
Functionality:
  • Creates a temporary layer named "points_to_CSV" with a yellow color for visual reference of exported points.
  • Extracts coordinates (X, Y, Z) for each selected point.
  • Generates unique point names based on the defined prefix and starting number.
  • Writes point names and their corresponding coordinates to the specified CSV file.
  • Places text labels with the generated point names at the corresponding point locations within the drawing.
I hope it helps you.
Sea-Haven
It may be worthwhile providing a sample dwg with the "selected AutoCAD points" clearly shown, the task is not a hard one. Really need to know what is a "Point".
